2014 Design
aleks_ader
90
Re: 2014 Design
amc wrote:https://pbs.twimg.com/media/BbXrzcmCMAAGH-t.jpg:large
I think the tunnel is illegal:
Article 3.8.4 wrote:Any vertical cross section of bodywork normal to the car centre line situated in the volumes defined below must form one tangent continuous curve on its external surface. This tangent continuous curve may not contain any radius less than 75mm :
c) The volume between the rear face of the cockpit entry template and 450mm forward of the rear face of the cockpit entry template, which is more than 350mm from the car centre line and more than 100mm above the reference plane.
Once the 'tunnel' is open at the front and back, the surfaces of the tunnel become 'external' surfaces, and must therefore be continuous with the outer surface of the sidepod.
You make paper slit and it is done. But anyway why you would do that? Nose design really restrict airflow underneath so cooling so low on very dirty air is very uneffective or unpractical....
theWPTformula
50
Re: 2014 Design
siskue2005 wrote: i didnt understand
are you talking about single pylon or both?
25mm thick per pylon and a total surface area of 5000mm^2 (both pylons combined). Sorry for the confusion.
theWPTformula
50
Re: 2014 Design
On the subject of sidepods I can't see a clear reason for under-tunnels or extreme undercutting (e.g. STR7). The 'pods will need to be bigger anyway so using an undercut will require the whole assmebly and internals to be lifted upwards, presenting a greater surface area higher up on the car. Would this not increase drag?
In my opinion I would concentrate more on the airflow around the sidepod. As mentioned above, the low nose heights limit the potential of an undercut sidepod anyway.
Could sidepod turning vanes and further enhancements to vortex generators be a significant area for development? VGs could help achieve some slightly ambitious sidepod designs to allow flow to remain attached longer.
240
Re: 2014 Design
I feel it's possible to see a top mount intercooler right above the engine with cooling air coming through the roll hoop.
eyalynf1
eyalynf1
Re: 2014 Design
ringo wrote:I feel it's possible to see a top mount intercooler right above the engine with cooling air coming through the roll hoop.
With the addition of the turbos relatively high in on the chassis, I think that teams will be looking to minimize center of gravity penalty, and maybe not placing an fluid filled heat exchanger this high. Or were you thinking of an air-to-air unit? Either way, I would try to find some place lower.
djos
113
Re: 2014 Design
I suggested tiny TEC powered Intercoolers with heat-pipes back to the main radiator over here:
http://www.f1technical.net/forum/viewto ... 55#p468855
I wonder if that would provide any packaging and/or CoG advantages?
"In downforce we trust"
eyalynf1
eyalynf1
Re: 2014 Design
I think this is a possible packaging solutions, but not necessarily a lightweighting solution. Interested in running the numbers with a sample TE component?
I've also got another idea that I may as well let out, as I'll never be able to develop it myself...
Why are they still using aluminum fin tube slab radiators? This tech is over 100 years old. In F1 they should be using custom formed, 3D printed, polymer heat exchangers. They would be lighter, optimized to actually provide some downforce and reduced drag, and shaped in three dimensions to fill an irregular volume as defined by an aero optimized exterior.
Anyone know if this has been looked into?
aleks_ader
90
Re: 2014 Design
eyalynf1 wrote:
djos wrote:
eyalynf1 wrote:I think this is a possible packaging solutions, but not necessarily a lightweighting solution. Interested in running the numbers with a sample TE component?
I belive that was already looked into, but its in my opinion to fragile and very unreliable. So i don't remember better or proper material with that heat, mass, anti-corosive and strength qualities like Aluminum. Sometimes is better go straight way and don't complicated to much... Even in rules most be some words or limitations about that.
djos
113
Re: 2014 Design
Most of the big F1 teams are using custom made radiators from Australian company PWR - they must be pretty damn high tech to steal business from the big European companies!
langwadt
langwadt
Re: 2014 Design
TECs are useless for almost anything more than a few watts, the efficiency is very low
eyalynf1
eyalynf1
Re: 2014 Design
I think it would be more appropriate to address the efficiency issue in terms of watts of cooling per mass unit of the TEC components, that is assuming that sufficient electrical input would be available from the kinetic and turbo recovery sources.
473
Re: 2014 Design
eyalynf1 wrote:Why are they still using aluminum fin tube slab radiators? This tech is over 100 years old. In F1 they should be using custom formed, 3D printed, polymer heat exchangers. They would be lighter, optimized to actually provide some downforce and reduced drag, and shaped in three dimensions to fill an irregular volume as defined by an aero optimized exterior.
My question is how well do polymers transmit heat? After all, we are talking heat exchangers, and it would be pointless to use a material with poorer heat trasmission properties than what is done now.
In any case, it is now possible to 3d print metal. I don't think there are machines that can do the size required, though.
The advantage would not be in better heat transfer, but it optimising the weight (ie reducing it) for the cooling capacity.
Holm86
249
Re: 2014 Design
Polymers have bad heat exchange. Thats why they are often used as insutaion.
Heat exhangers for F1 has been done in 3D printing. But I think that was an oilcooler. Don't know if radiator size are avalible yet. But I cant see a problem in going bigger. You just need a larger "tank" of sintered metal.
[youtube]http://www.youtube.com/watch?v=zApmGFDA6ow[/youtube]
Ferraripilot
21
Re: 2014 Design
djos wrote:Most of the big F1 teams are using custom made radiators from Australian company PWR - they must be pretty damn high tech to steal business from the big European companies!
It's my understanding Mercedes partnered with a US company to aid in design and produce their 'ultra efficient' systems since W03.
theWPTformula
50
Re: 2014 Design
Yes, apparently they are as much as 30% lighter than the previous system the team produced. Pretty impressive.
