yes it is, and yes it does make it easy to spotPup wrote:...if that's a mac thing or what...
About the .php part, a lot of image hosting sites use this to present their webpage together with the image, so nothing dodgy here.markc wrote:wesley123 wrote: This is just great. got some more info on it?Hi both, the hidden image in this case didn't come from f1tech, but a link I followed to a news story regarding Bernie and CVC. So far the hidden images here have been constrained to pixel trackers.Pierce89 wrote: Yes, please elaborate on this, as i've not noticed. Sounds pretty effed up.
My AV is however now refusing to allow me to see images from uploadpic.org, believing them to be dodgy. They're presented to the browser in the form of .php?imageguid which could be used to inject malicious code.
I also reported one of those posts to the mods, but I was informed that the link was indeed an image and on-topicBut then I couldn't tell thanks to AV being overzealous!!
Kind regards,
MarkC
Code: Select all
tags so it will show the [img] tag), I would like to know more and possibly test it out on a Virtual Machine.
Also if the mods didnt handle it because the post is on topic but the image is actually malicious then that is one step to far if you ask me.
Code: Select all
[quote="Judith27"][img]http://www.infoocean.info/avatar3.jpg[/img]PGs are mostly a tube so its easier to use them as a stressed member.[/quote]
Is it one also???Isabel412 wrote:The coil pack is a press fit on top of the plugs and the heat shield holds that in place.
They're just copies of sentences previously mentioned in the thread I think - not more than that.Pup wrote:The posts themselves are all vaguely on topic, but are really just fluff.
Please, use code tags to quote these posts, by that the image doesnt gets placed, so any form of malware doesnt get executed.strad wrote:This comes up from time to time..Is it one also???Code: Select all
[quote="Isabel412"][img]http://www.infoocean.info/avatar3.jpg[/img]The coil pack is a press fit on top of the plugs and the heat shield holds that in place.[/quote]
