2013 Testing - Barcelona 1: 19 - 22 Feb
diego.liv
diego.liv
Re: Mercedes AMG F1 W04
elf341 wrote:looks like big degradation though...
fernando is on the same run and lap times (he's a little better and with no relax lap as Rosberg had one)..btw Mclaren is seems nice with tyres
gray41
Lap time and run after it very similar to that of the RedBull.
Lewis Hamilton #44
2016
Poles: *****
Wins: ***
kooleracer
kooleracer
Re: 2013 Testing - Barcelona 1: 19 - 28 Feb
GrizzleBoy wrote:How far off are they at this stage, from the 2012 Barcelona pole position time?
Or even 2011 for that matter. Would be interesting to see how much closer they can possibly get regarding lap times after the loss of EBD.
Grand prix has different track layout, to compare i think you should look at last year test times. Raikonnen did 1.22.030 on the last day. So there are really pushing hard i think.
Irvine:"If you don't have a good car you can't win it, unless you are Michael or Senna. Lots of guys won in Adrian Newey's cars, big deal. Adrian is the real genius out there, there is Senna, there is Michael and there is Newey.They were the three great talents."
Juzh
161
2012 fastest lap by hamilton (DSQ from quali) = 1:21.707 (drs, kers, coanda)
2011 pole = 1:20.981 (drs, kers, EBD + off trothle EBD)
2010 pole = 1:19.995 (DD + ebd for RB)
kooleracer
kooleracer
2011 catalunya test 01:21.268 MSC.
2012 catalunya test 01:22:030 RAI.
elf341
elf341
Sure. I was just looking at what the time decay from the first to the second flying lap.
Code: Select all
Merc    1.6s   (1.22.6)
Ferrari 1.0s   (1.22.9)
RBR     0.8s   (1.22.9)
Lotus   0.6s   (1.22.6)
The lotus looks a bit better, at least when averaging over the first two fliying laps.
Mams
Mams
Where do you see the laps times ?
GrizzleBoy
GrizzleBoy
Thanks for the info/replies guys.
raymondu999
They both go through the chicane in the last sector, so identical layouts for race and testing.
失败者找理由,成功者找方法
andrewf1
Dyanxx wrote:Rosberg just went quickest with a 1:22.616 lap =D>
given the fact that last year they did a 1:23:005 in low-fuel Q3 with softs (or was it supersofts?) and DRS all around the track, this time on mediums in testing with an unknown fuel-load (and hopefully using the DRS only in the designated place) is an improvement.
Juzh
161
Juzh wrote:what about alonso's tyers?
Anyone knows his tyre choice for last stint? He did suffer masive tyre degradation. Started with his fastest lap, then droped to 1:30s after 9 laps.
Juzh
161
Mams wrote:Where do you the laps times ?
http://f1tests.info/2013.php?rev=on
k.ko100v
k.ko100v
k.ko100v
k.ko100v
given the fact that last year they did a 1:23:005 in low-fuel Q3 with softs (or was it supersofts?), this time on mediums in testing with an unknown fuel-load is an improvement.
Last year in Q3 they used Softs, wich are this year medium. So we somehow can remove the tyres as a factor, for comparising the pace. But In Q3 the car is with min amount of fuel, today the car has fuel for min. 5 - 7 or maybe 10 laps. And (maybe the biggest difference) last year they use DRS on every straight, today only on the start-finish.
Forza
238
AMUS wrote:16:48 Auch Alonso versucht direkt nachzulegen: 1:22.952 Min. - auch auf Medium-Reifen. Das reicht, um sich vor Vettel zu schieben. Aber Rosberg und Räikkönen kann er damit nicht gefährden."
