Post Thu Mar 28, 2013 6:37 pm
My weather prediction, a perfect weather(for Shanghai) weekend. Perhaps overnight rain on one of the days, but temps will be around 24-28 C Track about 33. This race will show us who's where really.
My mistake, mixed up head wind with tail wind.beelsebob wrote:Eh? A head wind down the straight means that the wings have a higher air speed, and hence produce both more DF and drag.Nando wrote:Pretty sure it´s the opposite.
Blowing south (or south west-ish) means head wind. Surely that would mean less drag with a head wind.
Right, the key is that the wind is blowing *from the* south, not blowing south.Nando wrote:My mistake, mixed up head wind with tail wind.beelsebob wrote:Eh? A head wind down the straight means that the wings have a higher air speed, and hence produce both more DF and drag.Nando wrote:Pretty sure it´s the opposite.
Basically what i was getting at is if the car is travelling south and the wind is blowing south there´s less resistance on the long straight.
And not "It means enormous downforce and drag down the straight" since the wind is blowing in the same direction the car is travelling at if the wind is blowing south.
The size of the circulations you're talking about are so large that for the purpose of a race track, it blows from a direction. Circles thousands of miles across are effectively straight lines on the 1-2 mile scale.godlameroso wrote:Wind doesn't blow in a direction it circulates from a direction, the difference is subtle, keep that in mind. What might be a tailwind through 3/4ths of the back straight may be a side wind before the breaking zone.
The S marker is at the south of the map. The wind is forecast to be blowing against the cars as they drive down the main straight.seventhsin wrote:Has Nando aligned the S marker with the south direction? Or the direction blowing to?
As above, weather forecasts always say something 'winds 4knots blowing south easterly' and yeah its the direction it's blowing from
All the data I'm privy to says otherwise, there is always localized eddy and vortex formation in air masses that can cause partial shearing forces in the overall flow direction in even unobstructed flow(thus a tail wind can become a side or even head wind temporarily). The statistically relevant flow of air can remain constant for hundreds of miles, but there will always be localized shifts. This is even observed in laboratory conditions in essentially closed loop air tunnels and can throw air tunnel data off. We noticed the effect was even greater when the pressure distribution in the tunnel wasn't uniform(the nature of a wind tunnel makes completely uniform pressure impossible). Once the tunnel pressure was stabilized to the maximum we could muster the effects were mitigated somewhat, but I digress, that is whole 'nother can-o-worms.beelsebob wrote:The size of the circulations you're talking about are so large that for the purpose of a race track, it blows from a direction. Circles thousands of miles across are effectively straight lines on the 1-2 mile scale.godlameroso wrote:Wind doesn't blow in a direction it circulates from a direction, the difference is subtle, keep that in mind. What might be a tailwind through 3/4ths of the back straight may be a side wind before the breaking zone.
Note – of course small variations, (or even large local variations) occur, due to the wind being funneled through or sheered around buildings, but that does not mean that the general trend is for a circular pattern over the circuit.
Yeah, he really broke the mould when he sat down to draw his tracks.Nando wrote:Then you have the high speed left/right handers. (which can also be seen in Abu Dhabi and probably other Tilke-tracks)
