hollus wrote:
I agree. Muuuch slower in the high speed corners. But interestingly, you are citing an ~17% deficit in speed, while the 2014 cars carry an 14% penalty in weight. Cars designers have clawed back a lot of what the regulations took back in power and in aero.
Not entirely correct because, in 2004, they had race fuel onboard for the qualifying laps.
Schumacher pitted on the 13th lap of the race.
In 2013, Fuel consumption in Suzuka was said to be 2.73 kg per lap, according to this:
http://www.jamesallenonf1.com/2013/10/j ... -play-out/
In 2011, it's said to be 2.9kg according to:
http://motorsport.nextgen-auto.com/Suzu ... ,1727.html
I couldn't find one for 2004, when they had V10s(which I guess have bigger comsuption?)
Let's use 3kg/lap, which gives an extra 39kg to the 605kg 2004 car. So, W06 was around 8% heavier than F2004.
We can make some rough guess at the impact of such weight difference in cornering speed.
Let's suppose W06 have similar downforce levels to a 2011 LMP1 car, which was around 1200kg @ 240kmh:
http://www.mulsannescorner.com/aerodata ... s102i.html
At ~210kmh, downforce is ~ 920kg and total load on tyres are ~1618kg. Now with the same downforce and a 644kg car weight, the increased acceleration will allow 2,3% more speed, but, as speed will be a bit higher, downforce will also increase slightly, which will again increase speed capability.... tyre load sensitivity will impose a limit slightly higher than this 2,3%, though
So, with a rough guess, the W06 cornering speed, at Degner 1, would change from ~210kmh to max of ~220kmh(4,7%)*, if it had 644kg instead of 698kg
*rough guess based on typical values of tyre load sensitivity
Imho, it's still a far cry(~30kmh or 12% less) from the "roughly weight corrected" cornering speed of the W06 to that of the other previous cars
PS: I know the calculation is far from accurate as real downforce value will change the real impact, as well as the actual tyre load sensitivity. But, it's just to give an idea and indicate how the +50kg weight factor is not the major one in the high speed cornering differences.
PS2: I don't know if it's appropriate to this thread, but would you like me to post the Interlagos comparisons between F1 2014 and LMP1? It's really telling how F1 is no longer the "pinnacle" in cornering speeds...
Hobbs04 wrote:
Obviously we have clawed back x amount but change of direction is more thrilling to the eyes then 361 kph down monza...
I entirely agree with you. If a car is doing 360 or 340kmh at Monza's main straight, it's almost indifferent, at least to me. If it's doing 200 or 170kmh at Parabolica, though, is a big difference to me.
@Moose, grip is different to handling. If you look into 2004 onboards, on average, they gave much more work at the wheel than the 2014 ones. For instance, have you ever seen a 2014 being this handful?
https://www.youtube.com/watch?v=lvlSq77oVlE
Please don't share this link elsewhere cause I don't want FOM removing that account
