Well I think if you move the material of the longer nose to make the shorter thicker/denser, than the energy absorbing will be the same. The big difference would be the distance/time it takes for the nose to crumple, so the negative acceleration will be higher proportionally, more "G"-s.MIKEY_! wrote: ↑28 Jan 2023, 23:29I would love to see the nose made shorter (and get rid of the silly swept wings) at the same time as reducing the wheelbase. But I assumed it was all crash structure in front of the monocoque, and if you make it shorter that reduces the distance over which crash energy can be absorbed and dissipated, meaning you have to add more material (and weight) to absorb the same amount of energy. Is that not correct?Vanja #66 wrote: ↑28 Jan 2023, 17:08400-500mm shorter WB with 100-200mm shorter nose (without swept front wing naturally) would help a lot, though only if the width decreases to 1.9m max. 50mm narrower tyres will do the trick. Leaving the bodywork width would increase the risk of race damage, so hotheads would take more care while overtaking.
But are the cells even longer?
They look practically identical to me, it's the nose and the backside that's much longer:
