Mercedes W14
Venturiation
Venturiation
101
Re: Mercedes W14
Cs98 wrote:
15 Feb 2023, 13:22
15 Feb 2023, 13:17
Venturiation wrote:
15 Feb 2023, 13:14
You can compare it to other cars it's still zeropods , just a different design
Zeropods
#-o what the w13 had will and always be the zeropods idea
They've ditched zeropods but developed the good ideas behind it to this new approach with an elongated but low sidepod and cannon exits.
Let's just call it the halfpod and be done with this argument.
Clearly they have slightly more volume overall than last season, but still way less than the other teams.
Some are calling it not zeropods to have the gotcha the zeropods was a failure argument
Let's stay on topic and just talk technical
from above you can see the melted zeropods
wjpbill
wjpbill
Re: Mercedes W14
The launch car has cable floor stays on it. The rendered images don’t. It’ll be interesting to see if the floor on the launch car is last years and the stays will go in Bahrain.
Venturiation
Venturiation
101
Re: Mercedes W14
wjpbill wrote:
15 Feb 2023, 13:26
I think we need to see it on track first today
DiogoBrand
74
Re: Mercedes W14
Several posts discussing what to call the sidepods when you're clearly not going to agree.
How about everyone calls them what they like and move on to more interesting subjects?
Cs98
Cs98
36
Re: Mercedes W14
Venturiation wrote:
15 Feb 2023, 13:25
Cs98 wrote:
15 Feb 2023, 13:22
15 Feb 2023, 13:17
Likewise you are maintaining it's "zeropods" to maintain some misplaced sense of pride that Merc got it right.
The truth is these sidepods are neither as small as they were last year, nor are they as large as the competition. They are squarely in the middle. Halfpods.
F1Krof
95
Re: Mercedes W14
Cs98 wrote:
15 Feb 2023, 13:34
Venturiation wrote:
15 Feb 2023, 13:25
Cs98 wrote:
15 Feb 2023, 13:22
No, the sidepods are neither small, niether large, they are normal sized sidepods only vertical. Hence Verti-pods is the most accurate word to use on describing the Mercedes' sidepods.
Wroom wroom
prox
Re: Mercedes W14
Cs98 wrote:
15 Feb 2023, 13:34
Venturiation wrote:
15 Feb 2023, 13:25
Cs98 wrote:
15 Feb 2023, 13:22
Semi pods not a full pod or a no pod just a semi.
JordanMugen
86
Re: Mercedes W14
15 Feb 2023, 12:18
From Albert Fabrega on Twitter
Should spill from the rectangular radiator inlet at different car speeds have less effect than spill from the old radiator inlet, which was widest at the critical area down by the floor and outwashing flow?
Very interesting! Thanks. That makes it more clear as to what they have done. The floor should be much better supported now. It's almost similar to the rival cars now as to where the sidepod intersects with the floor towards the rear of the car.
Cs98
Cs98
36
Re: Mercedes W14
F1Krof wrote:
15 Feb 2023, 13:44
Cs98 wrote:
15 Feb 2023, 13:34
Venturiation wrote:
15 Feb 2023, 13:25
This isn't true. You need to differentiate between inlet size and sidepod size. The inlet may very well be the same size as other teams, but the overall volume of the sidepod is certainly smaller. Though larger than the W13.
Ozan
Ozan
Re: Mercedes W14
clear evolution from w13 to f4 phantom, which is nice =D>
Andi76
Andi76
446
Re: Mercedes W14
Venturiation wrote:
15 Feb 2023, 13:14
Andi76 wrote:
15 Feb 2023, 13:09
Venturiation wrote:
15 Feb 2023, 13:03
It is zeropods
Absolutely not. Sidepods are clearly visible from the front, top and the sides. From the top you can even clearly see their shape from front to rear. Thats not Zeropods.
Zeropods
Look at the image directly above your post. Sidepods are clearly visible from front to back. Also they are much wider at the bottom than at the top. If these are zeropods, then the concept is already old, because then heavily undercut side boxes were also zeropods, just the other way around. From the front, you can see not a small, very high inlet - with the best will in the world, this no longer has anything to do with Zeropods.
Cs98 wrote:
15 Feb 2023, 13:50
F1Krof wrote:
15 Feb 2023, 13:44
Cs98 wrote:
15 Feb 2023, 13:34
I think no one disagrees with that. But they are too big to be called Zeropods now. Also flowstructure will be different.
Sonewhere in between last years and big pods. Sorry but thats not Zeropods anymore. They are just too big now. Just look at the big inlet in the image above! And how you can clearly see the sidepod from front to back....
Giblet
Giblet
Re: Mercedes W14
There was quite a bit said by Mercedces last year about the W13 having a fundamental design error they didn't catch, and were unable to fix in that car.
Do we know what that was, and if the W14 addresses it?
KeiKo403
KeiKo403
Re: Mercedes W14
They’re pods at the side of the car, let’s just call them sidepods…can’t believe I’ve allowed myself to be drawn into this and also contributed to the problem.
Vaexa
Vaexa
Re: Mercedes W14
With the disclaimer this could just be a fake launch floor, I find the lingering presence of the clipped floor "foot" a bit concerning.
That was introduced as a trial item at Spa last year and consequently kept but it always felt like a bit of a move of desperation to me, to limit some of the floor contact with the track around the diffuser. I don't think any other team runs it.
Venturiation
Venturiation
101
Re: Mercedes W14
about rear suspension, don't know if it's true
