In the speed trap, only 1km/h. 324 for Max, 323 for ChecoSirBastianVettel wrote: ↑31 Mar 2023, 05:23Does anyone know what the top speed difference was between VER and PER? I'm curious since they were running different rear wings.
Not surprising really. Ferrari will run the engine in tractor mode any session all year.organic wrote:
Interesting, I guess better corner exits for Perez with the higher downforce rear wing helped him reach similar top speeds. In that case I wonder what rear wing they'll choose for the rest of the weekend.organic wrote: ↑31 Mar 2023, 05:24In the speed trap, only 1km/h. 324 for Max, 323 for ChecoSirBastianVettel wrote: ↑31 Mar 2023, 05:23Does anyone know what the top speed difference was between VER and PER? I'm curious since they were running different rear wings.
Top speed is with DRS, the rear wing size matters very little if they both use the same mainplane.SirBastianVettel wrote:Interesting, I guess better corner exits for Perez with the higher downforce rear wing helped him reach similar top speeds. In that case I wonder what rear wing they'll choose for the rest of the weekend.organic wrote: ↑31 Mar 2023, 05:24In the speed trap, only 1km/h. 324 for Max, 323 for ChecoSirBastianVettel wrote: ↑31 Mar 2023, 05:23Does anyone know what the top speed difference was between VER and PER? I'm curious since they were running different rear wings.
Mainplane is not the same. The main plane is the main difference between Bahrain and Jeddah wings. Bahrain mainplane has more camber and a lower leading edge.dialtone wrote: ↑31 Mar 2023, 05:27Top speed is with DRS, the rear wing size matters very little if they both use the same mainplane.SirBastianVettel wrote:Interesting, I guess better corner exits for Perez with the higher downforce rear wing helped him reach similar top speeds. In that case I wonder what rear wing they'll choose for the rest of the weekend.
Good point. My brain is definitely not working at full speed yet at these crazy early hoursdialtone wrote: ↑31 Mar 2023, 05:27Top speed is with DRS, the rear wing size matters very little if they both use the same mainplane.SirBastianVettel wrote:Interesting, I guess better corner exits for Perez with the higher downforce rear wing helped him reach similar top speeds. In that case I wonder what rear wing they'll choose for the rest of the weekend.
What added grip? PER was on Mediums and VER was on softs, about the same age, VER took just about every corner faster. The difference I've seen on the mainplane seems minimal at best, weight has very little impact in the straight past 300kph, weight is irrelevant even in bike time trial races where they typically use bikes that weight 2-3kg more than the climbing bikes, favoring instead aero efficiency. The aero difference between those 2 wings is zero, which, if the more loaded one generates more downforce, is pretty impressive in its own accord.AR3-GP wrote: ↑31 Mar 2023, 05:31Mainplane is not the same. The main plane is the main difference between Bahrain and Jeddah wings. Bahrain mainplane has more camber and a lower leading edge.dialtone wrote: ↑31 Mar 2023, 05:27Top speed is with DRS, the rear wing size matters very little if they both use the same mainplane.SirBastianVettel wrote:
Also, looking at the speed trace on the best lap, Perez acceleration seems higher even when accounting for the added grip on corner exit. This is counterintuitive considering his bulkier mainplane and the new front wing.
There could be differences in fuel load. These were set on different laps.
edit: okay I see, different tire.dialtone wrote: ↑31 Mar 2023, 06:04What added grip? PER was on Mediums and VER was on softs, about the same age, VER took just about every corner faster. The difference I've seen on the mainplane seems minimal at best, weight has very little impact in the straight past 300kph, weight is irrelevant even in bike time trial races where they typically use bikes that weight 2-3kg more than the climbing bikes, favoring instead aero efficiency. The aero difference between those 2 wings is zero, which, if the more loaded one generates more downforce, is pretty impressive in its own accord.AR3-GP wrote: ↑31 Mar 2023, 05:31Mainplane is not the same. The main plane is the main difference between Bahrain and Jeddah wings. Bahrain mainplane has more camber and a lower leading edge.
Weight is utterly irrelevant on a flat time trial. They never change bikes in time trials no idea where you saw this happen, the stage is run at average speeds of 58+ kph, if you stopped to change bike in a time trial you'd lose instantly, the olympics time trial, aside from the winner, saw 2.6s between 2nd and 3rd, 0.4s between 3rd and 4th and 1.4s between 4th and 5th. And you would stop to change a bike? Nope. They cover their chains in wax because it improves efficiency of the drive train by 4W, use bigger pulley wheels in the rear mech because it improves efficiency of the drivetrain.
Here you go:AR3-GP wrote: ↑31 Mar 2023, 06:07edit: okay I see, different tire.dialtone wrote: ↑31 Mar 2023, 06:04What added grip? PER was on Mediums and VER was on softs, about the same age, VER took just about every corner faster. The difference I've seen on the mainplane seems minimal at best, weight has very little impact in the straight past 300kph, weight is irrelevant even in bike time trial races where they typically use bikes that weight 2-3kg more than the climbing bikes, favoring instead aero efficiency. The aero difference between those 2 wings is zero, which, if the more loaded one generates more downforce, is pretty impressive in its own accord.AR3-GP wrote: ↑31 Mar 2023, 05:31
1) I said added grip because Perez has a higher load rear wing but note that I am also dismissing corner exit differences.
2) There are two different wings.
3) I would suggest that you review your speed traces from a race to look at how top speed evolves with fuel load.
Look what I have to do:AR3-GP wrote: ↑31 Mar 2023, 06:39Verstappen has a double tow across the lineon lap 3. 4 tenths behind Magnussen, who was only 3 tenths behind Hulkenberg as they both crossed the line. The first laps created a big tow all around the circuit for following cars. Verstappen commented on how it made the rear unstable.dialtone wrote: ↑31 Mar 2023, 06:36Here you go:AR3-GP wrote: ↑31 Mar 2023, 06:07
https://i.imgur.com/ZjZdAXI.jpeg
VER v VER in Jeddah, 3rd lap (his 2nd slowest) and last lap (his fastest):
* Top speed on start line is identical (no drs)
* Top speed at T13 (~2000m) is 5kph off, the heavier car is accelerating faster than the lighter car, unfortunately the heavier car, due to being heavier is paying the much slower corner speed.
* Probably behind someone before T16 since VER gets DRS in his 3rd lap from that point on.
* With DRS active the car with 100kg more fuel is stupidly faster.
Weight is irrelevant for top speed compared to aero, especially in long straights like the back straight here in Australia or the main straight in Jeddah where the corner exit is recovered during the straight.
I rest my case.
It would make more sense to do a comparison using Perez, who did not have use of DRS after he passed Alonso on lap 3 or 4.
