I think the idea of the swan neck is to maximise the area of the lower side of the wing to generate downforce - you gain a few square centimetres of surface that would otherwise be taken by the support. However, to do it you need to move the wing support forward so that the swan neck can be formed to arch over the wing - if you don't then the support will still be below the wing. Moving the support forward would change the way their monkey seat is mounted and perhaps the monkey seat is a bigger net performance gain than a swan neck would be.JDC123 wrote:Is anyone else surprised Merc haven't gone with the swan neck rear wing support as all of their updates at the moment look very small, and fine detailed to get that little bit extra. I imagine the swan neck doesn't produce that much better performance but when you are mercedes you are looking at every little area.
The swan neck's real advantage is that there's no flow seperation on the underside of the wing. The underside is much more prone for flow seperation than the upper side of the wing. Also it's critical for the generated downforce. Essentially the flow get's seperated in a v-shape after any obstruction on the underside of the wing.Just_a_fan wrote:I think the idea of the swan neck is to maximise the area of the lower side of the wing to generate downforce - you gain a few square centimetres of surface that would otherwise be taken by the support. However, to do it you need to move the wing support forward so that the swan neck can be formed to arch over the wing - if you don't then the support will still be below the wing. Moving the support forward would change the way their monkey seat is mounted and perhaps the monkey seat is a bigger net performance gain than a swan neck would be.JDC123 wrote:Is anyone else surprised Merc haven't gone with the swan neck rear wing support as all of their updates at the moment look very small, and fine detailed to get that little bit extra. I imagine the swan neck doesn't produce that much better performance but when you are mercedes you are looking at every little area.
Sometimes in F1 (and racing aero generally) an idea becomes very trendy and everyone uses it. However, not everyone will necessarily assess whether the idea works for them in the way that they should. Perhaps Mercedes are bucking the swan neck trend precisely because it wouldn't work for them as well as their current design does. Perhaps Mercedes are right and everyone else is wrong...
All of the teams run a rib in line with the support post so the whole thing is a bit moot in my view. The Mercedes support post, as you say, is slimmer than the other teams and no worse than the rib. On that basis, I would say that the swan neck would provide little benefit to the Mercedes and that, presumably, is why they don't run it. They are the pace of the field so I say again, perhaps Mercedes have it right and everyone else is wrong...n4rf wrote: Thus their pillar is much much slimmer than the one of the teams running the hydraulic line through it. So it's certainly not a quick fix on the Merc. I still think that it would be somewhat beneficial, but then again I'm not an aerodynamicist or even in an F1 team, so what do I know.
But the swan neck support WILL give a performance boost, so considering mercedes have such a detailed car does it not surprise you they haven't gone down this avenue? The comment about the positioning of the monkey seat is irrelevant I think as it can be moved further under the wing with the current rules.Just_a_fan wrote:All of the teams run a rib in line with the support post so the whole thing is a bit moot in my view. The Mercedes support post, as you say, is slimmer than the other teams and no worse than the rib. On that basis, I would say that the swan neck would provide little benefit to the Mercedes and that, presumably, is why they don't run it. They are the pace of the field so I say again, perhaps Mercedes have it right and everyone else is wrong...n4rf wrote: Thus their pillar is much much slimmer than the one of the teams running the hydraulic line through it. So it's certainly not a quick fix on the Merc. I still think that it would be somewhat beneficial, but then again I'm not an aerodynamicist or even in an F1 team, so what do I know.
You don't know that it will give a boost. As I said, I think we can be assured that Mercedes will have looked at the options available and have come to the best package for them. If it made the car quicker then they'd do it.JDC123 wrote: But the swan neck support WILL give a performance boost, so considering mercedes have such a detailed car does it not surprise you they haven't gone down this avenue? The comment about the positioning of the monkey seat is irrelevant I think as it can be moved further under the wing with the current rules.
Maybe not. It is not so simple. As a previous poster mentioned above, the swan neck has to be an appropriate distance in front of the leading edge of the wing for it's benefits to come through. If it is too close the pylon will still obstruct the flow under the wing.JDC123 wrote:But the swan neck support WILL give a performance boost, so considering mercedes have such a detailed car does it not surprise you they haven't gone down this avenue? The comment about the positioning of the monkey seat is irrelevant I think as it can be moved further under the wing with the current rules.Just_a_fan wrote:All of the teams run a rib in line with the support post so the whole thing is a bit moot in my view. The Mercedes support post, as you say, is slimmer than the other teams and no worse than the rib. On that basis, I would say that the swan neck would provide little benefit to the Mercedes and that, presumably, is why they don't run it. They are the pace of the field so I say again, perhaps Mercedes have it right and everyone else is wrong...n4rf wrote: Thus their pillar is much much slimmer than the one of the teams running the hydraulic line through it. So it's certainly not a quick fix on the Merc. I still think that it would be somewhat beneficial, but then again I'm not an aerodynamicist or even in an F1 team, so what do I know.
My understanding is that they planned to introduce engine upgrades for the Canadian GP. Using 3 engines for the season would be detrimental performance wise, so they may as well use their full quota.Jolle wrote:Looking at the FIA reports, it looks like the Mercedes teams are still running their first PU this weekend.... With a bit of luck they can run the whole season on 3 engines.
Very good, i found the full res version :Moose wrote:Awesome picture from the BBC sport web page - you can really see how good a job Merc are doing of getting rid of the dirty air from the front wheels.
https://s3.amazonaws.com/f.cl.ly/items/ ... 20p.m..png
Not saying that they will, only surprised that they could.... They are not far of les mans durabilityBlaze1 wrote:My understanding is that they planned to introduce engine upgrades for the Canadian GP. Using 3 engines for the season would be detrimental performance wise, so they may as well use their full quota.Jolle wrote:Looking at the FIA reports, it looks like the Mercedes teams are still running their first PU this weekend.... With a bit of luck they can run the whole season on 3 engines.
