SundayMogster wrote:Are we having a Monaco thread?
And if somehow you find yourself behind a slower car, you better make sure it's Ocon in Mercedes powered car...MKlaus wrote: ↑13 May 2021, 19:27for anyone to go for an undercut, there has to be a window that opens behind. generally, that window opens first for the leader when he controls the pace. i don't think the leader would run away on this track allowing an undercut window for the car behind. if there is no window available and the trailing driver pits, he would come out behind a very slow mid field cars and ends up losing a lot of time allowing the leading driver to then pit next and come out ahead. it's all about how well the leader of the packs controls the pace. it rarely happens that a car that is not on pole wins in monaco. almost never in the last decade barring major cockups. that two driver against one doesn't hold water here.NathanOlder wrote: ↑13 May 2021, 18:26And if its 2 Mercs vs Max, then Bottas will go undercut with Lewis overcut. Max will struggle to win that one. Sergio better be in the mix
