Ferrari SF-24
Xyz22
Xyz22
123
Re: Ferrari SF-24
Vanja #66 wrote:
19 Sep 2024, 15:16
Properly cranked up on the front, looks good for more front bite. Let's see how it flexes :lol:
According to Formu1a.uno is similar to the first spec of the SF 23 front wing. Hopefully it will work :D
For the new page:
scuderiabrandon
102
Re: Ferrari SF-24
Vanja #66 wrote:
19 Sep 2024, 15:16
Ideally, that frontal area shrinks into the oblivion under enough load.
Re: Ferrari SF-24
Xyz22 wrote:
19 Sep 2024, 15:19
Yes, it's similar that the difference between central loading and the tip is a discrete drop, but overall when you compare to Monaco and Hungary SF24 specs, you'll see it has more frontal area, thus bigger angle. When proper photos for comparison come up we will see
scuderiabrandon wrote:
19 Sep 2024, 15:22
leblanc
leblanc
Re: Ferrari SF-24
Vanja #66 wrote:
19 Sep 2024, 15:16
Maybe Charles won't need +672 clicks after this
yooogurt
36
Re: Ferrari SF-24
FORZA FERRARI!
bananapeel23
Re: Ferrari SF-24
leblanc wrote:
19 Sep 2024, 16:54
Vanja #66 wrote:
19 Sep 2024, 15:16
Back to our regularly scheduled Leclerc domination of Sainz in qualifying, as is tradition when the car balance shifts forward.
pantherxxx
pantherxxx
Re: Ferrari SF-24
About the new front wing:
"The new specification doesn’t feature major changes or large differences in the flaps. Observing the mainplane and the second flap, the geometry has remained the same, indicating that the airflow path is correct and optimally feeds the floor.
What changes with the new specification are not the flaps but small elements that bring significant aerodynamic benefits. The innovations lie in the connection between the flaps and the endplate. These changes are visible compared to the previous specification, as the titanium support has now been “replaced” with a carbon fiber connection.
This is where a modification inspired by McLaren’s wing comes in. The last two flaps are connected to the endplate but feature a slight “curl.” This allows the new wing to generate a much more effective vortex toward the outside of the wheel. This modification introduces several advantages, as it accelerates the outwash flow and improves local low pressure for a better front end.
In addition to the changes in the joint between the flaps and the endplate, Ferrari is expected to have modified the arrangement of the carbon fibers. A different allocation of the layers changes the flex level of the elements depending on the applied force. This adjustment is necessary to “cancel” drag at high speeds, with the flaps lowering and then returning to the standard position below a certain threshold."
Source: https://scuderiafans.com/analysis-of-up ... ront-wing/
Ced
Ced
Re: Ferrari SF-24
