From an engine tuning perspective what they're doing is sheer insanity.
A regular B18 Integra GSR engine(1.8l 4 pot) has a 140lph fuel pump which is the same flow rate these cars use. No matter what port fuel injectors you use, you're limited by the fuel pump, with the stock pump you can't run more than ~6 psi of boost to maintain a safe .8 lambda. At 10.7:1 CR you're making about 340bhp @ 7,800 rpm on a GT35 ebay turbo. These engines are using the same fuel pump but running 45 psi of boost with 14:1+ CR making over 900hp, that the engines aren't exploding from detonation or are running at all is incredible when compared to what the budget build kids are doing.
