Mercedes AMG F1 W03
snoop1050
snoop1050
Re: Mercedes AMG F1 W03
Mestrades
Mestrades
-3
Joie de vivre
Anybody knows if they have ever worked on mercury system? Are they using it? Anything related to that system?
schumi57410
schumi57410
hello
all the time for Barcelona II for RBR, Mclaren, Mercedes, Ferrari and Lotus.
so we can expected that the 3 main forces are RBR Mclaren and Mercedes
http://www.scribd.com/doc/84691266/Barcelone-II
I make that, because we can expected that they test the same things.
thomin
raymondu999 wrote: DRS is only of any use if you're at maximum acceleration - or if you're on the straight - if you're at terminal velocity. You need to have enough downforce to take the corner flat out in the first place - THEN; you MIGHT have enough downforce to take it flat out, with DRS.
Wouldn't reduced drag also help during the acceleration? That would be the main benefit in quail IMHO.
MercAMGF1Fans
MercAMGF1Fans
Ok here's the proof,
In HD too.. slowed down as it was very fast
[youtube]http://www.youtube.com/watch?v=Nw3nKA8Seag[/youtube]
raymondu999
Yes - but you would still need to be on full throttle.
失败者找理由,成功者找方法
dren
226
It would help with any acceleration.
Honda!
raymondu999
Yep it would. That's its main benefit (other than a higher terminal velocity)
失败者找理由,成功者找方法
dren
226
Notice the strakes in the diffuser how they concentrate everything to the center of the diffuser exit? The W03 is one of the only (might be the only) car to not have the extensions below the rear wing endplates. Those help to move the flow outward of the diffuser. The mini-diffuser must have a very strong effect if they are concentrating flow towards it under the car.
Honda!
Rikhart
Rikhart
19
dren wrote:Notice the strakes in the diffuser how they concentrate everything to the center of the diffuser exit? The W03 is one of the only (might be the only) car to not have the extensions below the rear wing endplates. Those help to move the flow outward of the diffuser. The mini-diffuser must have a very strong effect if they are concentrating flow towards it under the car.
Either that, or they messed up completely in reading the regs, for the third year in a row.
raymondu999
MercAMGF1Fans wrote:Ok here's the proof,
[youtube]http://www.youtube.com/watch?v=Nw3nKA8Seag[youtube]
The DRS is open between Turns 2 and 3 - but I don't see it open in a corner in that video?
失败者找理由,成功者找方法
Metalrulz
Metalrulz
-1
The extended rear-wing endplates are placed behind the diffuser and the air that exits the diffuser would come in contact with the endplates so how would the endplates help in moving the air away from the diffuser ?
dren
226
They help with the air exiting the diffuser, yes. I meant they help with the flow exiting the diffuser on the sides.
Honda!
Richard
Richard
Another tidy up following several reported posts ...
Team chatter :arrow: viewtopic.php?f=1&t=12070
Speculation about F ducts, W ducts and stalled wings now has its own thread :arrow: viewtopic.php?f=6&t=12199
