Giorgio Piola whom is well respected in F1 is the one who broke the no wind tunnel parts story. All the focus is on the Barcelona update in which we'll see a new rear suspension amongst other things.JimClarkFan wrote:
Sigh... this disappoints me.
If they have not made a significant step forward by Barcelona, their season will effectively be over.
I think it would be better if they keep the exhausts in the position they were and fix whatever the aerodynamic problem at the back actually is. If you are correct, moving the exhausts forward is a half solution.
Link
The new McLaren were not made in the wind tunnel!
Woking engineers admitted that some parts have been modified with gumption
McLaren relies on experience rather than science. At a time of serious crisis in which the MP4-28 revealed major problems due to aerodynamic rear over-dependency by varying the height (the British call pitch sensitivity) that makes the car unstable in behaviour and hard to ride, engineers have relied on pragmatism to try to recover.
REVOLUTION IN SPAIN waiting for it to arrive the new rear suspension with a completely redone for the Gp of Spain, you are trying to put an impromptu solutions the two drivers, Jenson Button and Sergio Perez, to defend themselves better than has happened in Australia and Malaysia.
Diffuser cut like you might see in this column has changed the side of MP4-28 which is now more rounded in the area of discharges, renouncing the slenderness that had been found in the area of Coca Cola. Effe 1 Tech image, you can see the change that was made to the speaker that was "cut" on the two sides to increase the airflow between the rear wheel and wing support.
CHANGES of COMMON SENSE these novelties are not the fruit of painstaking research work in the wind tunnel, but are the findings that emerged from the "common sense" of technicians led by Tim Goss and his experience: after Malaysia there would not be time to follow the entire process for the resolution of new pieces.
SKIPPED the WINDTUNNEL design of particular parts, the making of the scale model for the wind tunnel, testing in the wind tunnel, data analysis and then proceed to the construction of carbon fiber material that requires a specific processing with non-collapsible times (autoclave cooking): these are the steps that require a few weeks to decide on new parts.
Save time and is for this reason that Woking technicians have taken the responsibility to skip some steps (for example the wind tunnel) to accelerate the creation of the package that arrived in Shanghai: f. ultra-modern 1, so if you can still find answers to problems without necessarily being limited by technology ...
