irsq4
irsq4
-1
Re: Mercedes Power Unit
gruntguru wrote:
29 Apr 2017, 10:34
5 litres consumption sounds about right to me. Assuming they use about 140 litres for the race, 5 litres is about 3.5% of fuel used. Although that is on the high side, you need to remember that a normal race engine with the same power would use about 240 litres of fuel and 5 litres would be 2% of fuel used.
14 l
568
Wow! Is that a truck engine?
Singabule
Singabule
irsq4 wrote:
01 May 2017, 09:06
gruntguru wrote:
29 Apr 2017, 10:34
14 l
From oil tank alone guaranteed minimum 5 liter, on engine May 4l. Off course if they can bleed oil to breather or compressor, they will get instant power in qualy but in race the effect would minimum. Wonder how they evaporate oil so it would effect power but not create deposit on jet chamber
648
so we're saying that in a race limited to 105 kg of hydrocarbon 'fuel' the eg Mercedes engines can burn around 109 kg of hydrocarbon ?
so when Mercedes talk about a bte of 49% is that a 'fuel' bte or a hydrocarbon bte ?
just asking ....... as I did 4 years ago
The hypothetical extra 4kg of hydrocarbon burns less efficient than the proper fuel - way less efficient. There is just more fuel to burn in addition to what you were burning under 100kg/hr fuel flow limit.
Back to the oil consumption figure. Shall we ask someone on the inside what the oil capacity and consumption is? Not that I don't trust guru but.. it would be great to get it from the source. Also it gives some more bones to pick.
supermarine
supermarine
So have merc actually brought an updated engine to this race?
dans79
267
supermarine wrote:
12 May 2017, 22:37
yep, new ICE, TC,MGU-H, & MGU-k.
http://www.fia.com/file/56796/download?token=sixwB2Lo
201 105 104 9 9 7
etusch
131
İs there water leak problem on Bottas pu
The updates are said to be reliability updates.
supermarine
supermarine
The consensus seems to be that the the phase II PU doesn't produce more outright power than the phase one but can spend more time operating at the higher engine modes during its lifetime. So the extent to which it is an improvement ought to be more obvious in the races than in qualifying.
SectorOne
say i got my hands on a bottle of oil from Mercedes Petronas, what would it say on the sticker?
5W-30 or something much more extreme?
470
SectorOne wrote:
17 May 2017, 06:00
Ingestion may cause harm to internal organs.
dren
227
SectorOne wrote:
17 May 2017, 06:00
10W-40
Honda!
SectorOne wrote:
17 May 2017, 06:00
0w-5 roughly.
The thinner oil they tried last year was rumoured to be a 0w-0
Singabule
Singabule
10w 60 for race, used to 5w 30 for qual
