WhiteBlue wrote:
I'm not asking for zero downforce OM. We are talking about five times the weight of the car today at top speed in total of weight and DF. If you reduce that to two times or three times you would still have plenty enough to accelerate at max rate. Just consider that the first 150 km/h are done almost without DF because it is an exponential increasing function. Traction for linear acceleration would still be plenty enough. Have you seen electric cars almost without DF out accelerate a Ferrari. It shows that the traction problem zone is not where DF is making the big difference. Once you are into the upper half of the speed range the DF is still building so fast that you never run out of traction for straight line acceleration. Just compare the Force Indias and the Red Bulls this season. The FI is faster on the straights and slower in the fast corners due to less DF. You would have to cut an awful lot of DF until an F1 car gets into a range where it accelerates with less performance. I'm calling fantasy on this one.
The problem is that you don't have 0kg at 0 speed; The sole hydrostatic pressure differential makes some kg and the as soon as the speed increases the curve is lifted.
So it is not true to say up until 150km/h you have no DF..150km/h is already a speed at which the F1 car has 1g of DF on it.
As for running out of straigth line acceleration, you have to see that an F1 car can still spin a 200km/h to understand that traction is always limited.
The only case where DF should be limited is in the top speed range; There, where the acceleration rate drops below 1G, DF is hampering the top speed.
And there's one very simple solution to that: Adaptive aeros...
Ogami musashi wrote:. The Monza package goes up to 360 km/h until all the power is absorbed by drag. The Monaco package tops out at 290 km/h. It means the HDF package has massively more drag. It is designed for max DF and not for min drag. It proves my point that there is plenty of scope in the present configuration to emphasize low drag over max downforce.
First, you are making the numbers; Since 2007 the cars top speed at monza are 345km/h. Second you're comparing apple and oranges; 290km/h at monaco is for a tunnel which is shorter than the straight line at monza and more importantly in which you enter from a low speed corner compared to the parabolica in monza.
If you want to compare, then compare with what are called the efficiency tracks (where you try to have the best L/D ratio) and you'll see top speeds of 315km/h average so only 30km/h short of the monza set up.
As i told you the increase in DF is not followed by a linear increase in drag not at all..there's an average factor of 2 or 3 in favor of DF.
That's the very reason the highest DF/D ratio is achieved with the highest DF trims.
And that is under the actual regs, that is regs that do not favorize efficient aeros. With GE tunnels and active aeros you could achieve the same level of downforce for half the drag.
See the indy car delta wing concept.
I think I will return your compliment here. Pure bullshit! Let us take any another famous corner and look at it the other way round. ATM F1 runs turn eight in Turkey less than flat out at 270 km/h with a downforce package that tops out at 320 km/h. Drivers go off there when they make a mistake in judgement of how much power they want to carry. Now let us assume that we take the Monaco DF package to Turkey. We would still go through turn eight with close to 270 km/h but flat out with massively more DF because our package is designed to top out at 290 km/h and we would probably still be accelerating. The example shows that you can make any fast corner become a challenge or a bore fest depending of the DF and power you carry. Reducing DF will make most fast corners a bigger challenge than they are today where excessive DF has killed the need to skillfully balance a car on the throttle through most of the fast corners.
You're making numbers again; This is to easy to draw an argument on made up facts.
Of course NOT, if you had more DF you would take the corner faster!
The only example where you are right is precisely those corners taken at the full top speed where indeed, power is missing (or too much drag..).
Again...If DF made fast corners on rails as you said with no grip problem the driver would have one choice: Taking the shortest line possible until grip misses; in that case you wouldn't be on rails anymore..and if the DF was so high that you any short line into the corner did have enough grip then the driver would simply follow the inner curve.
You can see that on some large and wide corners in F1.
And one exciting thing of F1 (and all DF cars) is that because the grip increases with speed it is crucial to exit the previous corner fast to take the corner the fastest possible (at the limit of grip);
