Lotus E20 Renault
Gridlock
30
Re: Lotus E20 Renault
I count at least 3 hydraulic/pneumatic hoses and junctions coming out of the channels adjacent the tethers, no?
#58
raymondu999
失败者找理由,成功者找方法
bhall
bhall
244
Really?
(Click to enlarge)
Red Schneider
Red Schneider
And here I was starting to think Lotus was becoming cool again after the whole naming saga. Sigh. Back to zero.
Kiril Varbanov
147
Gridlock wrote:http://img526.imageshack.us/img526/7716/lotuse20.png
I've disabled the IMG tags, no need to re-quote it too many times. I think I see position sensors close to the torsion springs?
Testarossa2012
Testarossa2012
Picture from Spanish Grand Prix:
Main teams front wing comparison:
http://formula12012testjerez.blogspot.c ... -prix.html
I hope you like it
bhall
bhall
244
That wing looks very damaged.
mx_tifoso
mx_tifoso
Damaged, but not TOTALED. :mrgreen:
Testarossa2012
Testarossa2012
bhallg2k wrote:That wing looks very damaged.
Uppps. Romain Gorjean seems have lost the TO
From Qualifying:
korzeniow
korzeniow
http://www.formula1.com/news/technical/ ... 9/968.html
That's confirms it. The team had to pass crash test again with the sidepods update, like Mercedes did
February 5, 2013
Richard
Richard
Team talk including the car's overall performance have been moved to the team thread :arrow: viewtopic.php?f=15&t=12240
The aim of the car topics is to focus on features of the car itself. If a comment doesn't relate to an object on the car, then it doesn't belong in this topic. Further debate is in the moderating discussion. :arrow: viewtopic.php?p=348837#p348837
madly
madly
Q&A with James Allison before Canada
How different will the car be?
We’ll be taking a smaller rear wing with a front wing set up to balance that. One of the key factors is to make sure we have our braking configuration correctly set up with good levels of cooling to survive what is a very arduous race for the brakes. Luckily the car has been quite good on brakes throughout the year to date with no real issues to report.
How much of a concern is braking in Canada and what can you do because of this?
There are several high speed straights into low speed corners so the brakes receive repeated extreme use over the course of a lap. Canada is the most challenging circuit of the year from the point of view of the brake wear. Brake wear is largely a function of brake temperature, and so a lot of work must be done (using tools such as CFD, the wind tunnel and a brake dynamometer rig) to ensure adequate aerodynamic cooling of the disks and pads.
techF1LES
176
Two different versions of the front wing (note repositioned cameras:
Front wing viewed from behind:
korzeniow
korzeniow
techF1LES wrote:Two different versions of the front wing (note repositioned cameras:
[img]http://img2.auto-motor-und-sport.de/Lot ... 37.jpg[img]
The upper one is China spec, the bottom one is Barcelona spec but in Monaco configuration (has gurney flaps).
I'm supprised they brought bigger downforce frnt wings. In Bahrain they used Melbourne spec FW over China spec...
Reason: Removed image quoted from earlier post
February 5, 2013
Neno
Neno
-29
i wondered if team decided to race with high front downforce wing, and low downforce rear wing. what can you gain in this configuration? too much front downforce over rear can hurt car stability?
i know last year they brought special front wing for canada race, and it didnt work out well, to low downforce numbers. and because of that they had problems in race.
