WhiteBlue wrote:When I listen to Norbert Haug's statement I conclude that the FOTA working group is discussing a down sized, direct petrol injection engine with fewer cylinders than eight, turbo loaded with about 600 bhp. That power figure would include or not include unlimited KERS. We cannot know how it is meant. My impression is that the ICE would have 600 bhp stand alone without the secondary electric power from KERS.
To reach fuel efficiency targets the new engine formula would most likely work with a total fuel load limit which would be set individually per race track. The fuel allowance would be set low enough to avoid the levels of aero forces that we have this year. The agreed 2011 aero is also a good starting point for 2013 unless we get more information in the next two years. I believe that the initial 2011 aero level is the maximum F1 should have in the future. Fuel allowance should become more restricted for every efficiency gain that teams make. This would keep performance on a constant level which is desirable. Level performance avoids increasing safety measures which are costly for track owners and constructors.
Bernie has been talking about a standardised engine size, throughout all the main series, and in WRC. 1600cc is the size mentioned, but as the optimum cylinder cc is considered to be 300cc, I would imagine that 15oocc, 5 cylinder engines would be more likely. However, I would like to see an engine size mentioned, but leaving the layout, cylinder number etc open. That could lead to a flat 10 screamer, down to a 3 cylinder thumper. But the engineering possibilities would be interesting.
