F1_eng wrote:
Just to show the behaviour a single element wing would exhibit with a blown section. Done on one of my home computers very very quickly, maybe 15 mins from drawing the section to acceptable convergence.
I'll bite. My liberal arts degree doesn't help me read these, but: I see a couple of things. An overall increase in velocity under the wing (good for a diffuser?). But at the wing itself a large vortex has formed downstream of the jet. And air upstream of the jet has slowed.
Also, the velocity above the airfoil has increased, but above and behind the airfoil it is slower. Velocity immediately under the wing is very low. Higher pressure below than above.
The overall effect is like changing the profile of the wing. With this new profile (shaded area) the flow stays attached and highly energized much longer than without the jet.
Overall, less disturbance to the air downstream of the airfoil.
I only wish I could see a higher aoa model, just with a lower pressure jet, say, yellow/green
I'm guessing the size of the vortex correlates to the pressure of the jet.
Kelpster
