Ther passing car does not have to use the wing flattener. It is up to the driver to know how to handle his car, in ALL circumstances!autogyro wrote:You wont think that when some driver tries to pass another on the inside of a fast curve and the reduced DF on the rear upsets the aero balance and slides the rear end into the car being passed.
The testing ban is a FOTA initiative, when they want to change it FOTA will say so and it will be rubberstamped.andrew wrote:Rule changes for next year:
http://www.crash.net/f1/news/160891/1/f ... uncil.html
I'm not sold on KERS but lets see what happens and they have not reviewed the ridiculous (and dangerous) testing ban.
autogyro wrote:Realy and you have thought this one through fully?
Unfortunately you make a lot of claims! I would point out that this year, and last year, F1 cars have used movable aero parts. Further, in years gone, there were adjustible rear and front wings, and few, if any accidents attributable to these. Other high power formulae, use movable devices, without problems. I don't like the idea, but some of the comments are ridiculous. Your original comment seemed to imply that during an overtaking move, on a corner, the wing would move without warning to the driver. I pointed out that it was the driver who would control its use, and therefore would be aware of the change in handling. And so what if the car hangs its tail out?? Watch some videos of races between 1920 and 1990!autogyro wrote:I have and I have also driven race cars under test with moveable aero.
It can be extremely dangerous.
Forget the arguments over whether it's dangerous or not - if used as designed then it's not dangerous, if it breaks (Red Bull I'm looking at you) then it could be very dangerous. The slipstreams of old did not have the possibility of breaking!gilgen wrote:Unfortunately you make a lot of claims! I would point out that this year, and last year, F1 cars have used movable aero parts. Further, in years gone, there were adjustible rear and front wings, and few, if any accidents attributable to these. Other high power formulae, use movable devices, without problems. I don't like the idea, but some of the comments are ridiculous. Your original comment seemed to imply that during an overtaking move, on a corner, the wing would move without warning to the driver. I pointed out that it was the driver who would control its use, and therefore would be aware of the change in handling. And so what if the car hangs its tail out?? Watch some videos of races between 1920 and 1990!autogyro wrote:I have and I have also driven race cars under test with moveable aero.
You are not the only person on this forum who can claim to have driven cars with movable aero. Yet you seem to claim that it is dangerous! What car did you test, and when. I would be interested to know
You talk as if mechanical grip would constitute a problem to good side by side racing. The opposite is true. Mechanical grip rules in slow corners and those have not been a problem for close racing at all.myurr wrote: As has been demonstrated time and again ever since it was first raised by the Toyota aero guy and on the James Allen blog, the real problem with F1 isn't the aero it's the mechanical side of things...
Make the tyres marginal and reduce mechanical grip in the dry and you instantly improve the spectacle...
Mechanical grip on it's own is obviously not an issue, however huge levels of mechanical grip in combination with the aero of a current F1 car does constitute an issue. The easiest way to demonstrate this is to look at a damp race - take away the mechanical grip and the cars have no problems racing each other in close formation.WhiteBlue wrote:You talk as if mechanical grip would constitute a problem to good side by side racing. The opposite is true. Mechanical grip rules in slow corners and those have not been a problem for close racing at all.myurr wrote: As has been demonstrated time and again ever since it was first raised by the Toyota aero guy and on the James Allen blog, the real problem with F1 isn't the aero it's the mechanical side of things...
The problem occurs when cars have to negotiate fast to medium corners in close proximity. The leading car produces twice as much aero grip as the following car and any advantage the follower may have gained in the slipstream is taken away by the downforce disadvantage of running in dirty air.
If it were possible to make the tyres hard enough to avoid marbles off the racing line that would help a little bit actually. As long as tyres are safe and the same for all I personally do not care much for the performance level they provide. Tyres should be a neutral issue like fuel and not something that influences the race outcome. I would much prefer an extremely durable prime tyre which can run the whole race and offer limited advantage to the option tyre in terms of lap time. I would not mind at all if they go back to wide tracks and fatter tyres as the turbos of old had.
I agree with some of the sentiment but for me the WDC is more important than the WCC, and I suspect the same is true for the majority of fans even amongst those on this board. Unfortunately a battle between drivers on an equal platform to see who is best is mutually exclusive with a battle between constructors to see whose car is best. What we currently strive for is a situation where by the gaps between the top teams are small enough and fluctuate enough from race to race that the driver has a real impact on deciding the WDC - those drivers that make the most of their bad days as well as pressing home their advantage on the good days will be the ones that rise to the top of the championship.WhiteBlue wrote:For me the F1 WCC should be an engineering battle for the most fuel efficient chassis and power train. Any development that improves the efficiency should be allowed unless it constitutes a driver aid such as launch control, ABS and ESP. Adaptive and adjustable aero, mass dampers, active suspension and other fuel saving technologies should be allowed as long as the fuel budget is small enough to limit the use of aerodynamic forces to a minimum.
Your first three sentences contradict each other and ultimately end up agreeing with me. The aero is the same, the lateral acceleration cannot build up due to reduced tyre grip and aquaplaning. Whilst I'm sure the tyre companies cannot reproduce this effect exactly, there is no question that they could produce a tyre that in the dry behaved more like current wet tyres in terms of the level of grip and propensity to slide. This should help with the races, and I am backed by a public interview with a Toyota aerodynamicist. Whilst he would no doubt have certain biases, I would hope you agree that he would be vastly better informed than either of us.WhiteBlue wrote:You cannot compare wet and dry races. Aerodynamics basically do not work in wet races as designed. You still get the downforce but the lateral acceleration cannot build up to the level as seen in the dry due to much reduced tyre grip and aquaplaning. The tyre grip seen in wet race cannot be achieved under dry conditions.
Yes yes, FIA good FOTA and the teams bad. This is one proposal, but there have been many other attempts by the FIA often in collaboration with the team to control the levels of downforce in the name of helping the racing. 2009's aero rules were a prime example of this. At least at the beginning of the year the downforce levels were much reduced from the previous year yet there was no real increase in the ability of cars to follow each other closely.WhiteBlue wrote:To say that the FiA has tried to cut aero forces without success is misleading. The FiA has made a very sensible proposal to cut downforce to 1.25 metric tons which has been rejected by the teams for their own selfish reasons. The passing/aero problem could be history since 2007 if the teams had accepted the FiA proposal.
It's not really a fair comparison as the downforce and drag of the cars at speed are going to be dramatically different. However there is one reason alone that the efficiency of F1 engines has stagnated, and that is the engine homologation rules brought in by your beloved FIA. You're also comparing diesel engines to petrol, which is not a direct like for like comparison. I'm sure you know the energy density of diesel is greater than petrol in addition to any efficiencies of the power plants themselves.WhiteBlue wrote:F1 engines may have been efficient for the power level they produced some years ago but in the last five years the efficiency of racing engines has moved in leaps and bounds (as witnessed at LeMans some weeks ago). The Audis and Peugeots were using 48L/100km for a heavier car with 900 kg. F1 uses 75L/100km with 560 kg, is seriously behind the game and needs to catch up.
