2024 Scuderia Ferrari F1 Team
SQ went as good as it could, the gap is as expected with temperatures dropping as much. Both drivers did a great job. Sprint looks to be safe from rain and it might start pouring right after the medal ceremony. Let's see if Mediums combined with less fuel can give Ferrari some edge early on.
As for incoming wet Q session, we shouldn't expect any miracles, 3-4-5 will be great positions to start from. The race looks set to be wet from start to finish, 90% chance of rain basically. Been thinking about something today, all might not be lost in the wet. Everything depends on tyre warm up, if that goes well early on and this specific scenario I have in mind happens, I will explain it after the race.
Until then, it's great reading a pumped-up Vasseur asking the team to push and attack for Sunday points
https://scuderiafans.com/track-surface- ... zilian-gp/
AeroGimli.x
deadhead
52
The weather in São Paulo seems to be very dynamic so it might still be a dry race...
Seanspeed
Seanspeed
aleks_ader wrote:
01 Nov 2024, 22:52
Luckily Brasil is no so favourable in terms of track position. Wil see. Mclren should this had in pocket but who knows maybe they again hit graining. Sprint should be ok for them maybe. IDK
For the start, no, it's such a short run to T1, it's hard to make up ground there without somebody else getting a bad start or bad luck.
But it's a long straight that you can absolutely pass on, and the Ferrari has good straight line speed. If they have any kind of race pace advantage, it wouldn't be impossible for them to utilize it even starting behind Mclaren. Not easy, but potentially possible.
scuderiabrandon
102
deadhead wrote:
01 Nov 2024, 23:27
Chance of rain for Sunday is around 60% at the moment. Meteoblue is at 20-40% model confidence now.
Space-heat
Space-heat
Vanja #66 wrote:
01 Nov 2024, 22:52
Charles unfortunately will start the sprint on 3 lap older Medium (6 lap old), than those around him. Might be difficult to push McL, will depend what has been taken out of the M with the extra push lap.
Fer.Fan
Fer.Fan
Space-heat wrote:
02 Nov 2024, 00:21
Vanja #66 wrote:
01 Nov 2024, 22:52
Do Charles and Carlos any new sets M for the 1:st stint in race on sunday??? To my knowledge all M are used.
Fer.Fan
Fer.Fan
Space-heat wrote:
02 Nov 2024, 00:21
Vanja #66 wrote:
01 Nov 2024, 22:52
search
Fer.Fan wrote:
02 Nov 2024, 10:47
Space-heat wrote:
02 Nov 2024, 00:21
Vanja #66 wrote:
01 Nov 2024, 22:52
yes, everyone has
based on my notes and official Pirelli file: https://i.redd.it/lusy4zebsdyd1.jpeg
ScuderiaLeo
Terrible pace today. What the hell?
Autobahn303
Autobahn303
This lico situation is getting ridiculous
franbatista123
Could Ferrari with Charles be running a more conservative engine mode in Sprints? He's usually slower than race day.
Space-heat
Space-heat
ScuderiaLeo wrote:
02 Nov 2024, 16:32
They had to change the set-up post FP1 as the track was bumpier than expected and the quali pace was down.
The LiCo for Charles is ridiculous. On the radio Charles mentioned he pushed too much too early. Not sure on Carlos. We def look a step behind Max and McL on race pace. Hopefully some the sprint info can help tune the set up in. Otherwise it is P4-P5 tomorrow again...or Max could cause some chaos and help us out.
ScuderiaLeo
Autobahn303 wrote:
02 Nov 2024, 16:36
dialtone
dialtone
121
ScuderiaLeo wrote:
02 Nov 2024, 16:41
Autobahn303 wrote:
02 Nov 2024, 16:36
LMAO.
Ferrari should just change the engine and take the penalty.
What happened to his engine #2?
https://www.f1technical.net/news/24680
Autobahn303
Autobahn303
ScuderiaLeo wrote:
02 Nov 2024, 16:41
Autobahn303 wrote:
02 Nov 2024, 16:36
Just as shitty as the server this website is using.
