Yes, I considered a 50/50 weight distribution instead aof 40/60. To be honest there are no advantages in such a configuration... except the elegance of general shapeRicME85 wrote:Its a shame there is no scope in the rules to be able to do a front engine car
Look, with that L/D, just remove your rear wing. You will surely have much less drag, the car might be balanced and you are all set.AratzH wrote:... my main problem is CoP position.
Yes, I didn't have the time to change the aero concept. I'll probably make the exhaust blow into the dissuser in the next release.LVDH wrote:Cool car! The only downside I see is your exhaust positioning. The driver might complain. Why not in front of the front wind shield?
Wich L/D race do you expect for the next races? Better o worse ration than during the high downforce races? Will the best car still have a 4.5 ratio?LVDH wrote:I took the time to plot L/D for all of the cars
Are you going to fire him?LVDH wrote:To make matters worse some dumb employee must have taken his smartphone to the virtual wind tunnel and leaked the footage of the new car
I am pretty sure that it will be much higher as there will not be any crazy devices to produce just that little bit of extra down force at any cost anymore. So we should see values better than 5.0CAEdevice wrote:Wich L/D race do you expect for the next races? Better o worse ration than during the high downforce races? Will the best car still have a 4.5 ratio?
Well, as I cannot change my brain I have to try different tools to finally win.CAEdevice wrote: Nice car, it seems an evolution of the latest one.
Are you using Xflow? Very interesting and not conventional software!
I can understand. Since I can't change my brain and I have only one tool, I try to bring fresh air designing the front engine version of my carLVDH wrote:Well, as I cannot change my brain I have to try different tools to finally win.
These are the corrected numbers.machin wrote:Out of interest Chris, are the COP numbers the "actual" or "KVRC corrected" figures?
Unfortunately I don't have access to the full simulation results for this round, so I'll see if I can find something else to post.AratzH wrote:Now "naked" pictures of the top teams this time??
Actually I was thinking of a similar solution for race 4... and some other things...LVDH wrote:Look, with that L/D, just remove your rear wing. You will surely have much less drag, the car might be balanced and you are all set.AratzH wrote:... my main problem is CoP position.
For a bit of fun... I adapted the Virtual Stopwatch base car to represent a front engined car with 50:50 weight distribution and ran your numbers:-CAEdevice wrote:Hi everybody, as I announced after the second race, I prepared a surprise for the 4th race... even if I don't think it could race!
I tried to design someting rule compliant, moving the engine template in front of the footbox template, and moving the cockpit rearwards. The base was my "regular" MP003, the version used during the 2nd and the 3rd race. The Panoz Spyder inspired me too.
What do you thing about?
http://www.caedevice.net/KVRC/MP003_Front-engine.jpg
Yes, I know I would had better to spned my time improving the "official" project, but I need to refresh my ideas
Here are some numbers:
DR: 1950N
DF: 6800N (I've run only two test to optimize it)
COP: 1.5m
Thank you machin for adapting the Virtual Stopwatch settings.machin wrote:For a bit of fun... I adapted the Virtual Stopwatch base car to represent a front engined car with 50:50 weight distribution and ran your numbers:-
Nurburgring lap times:
Assuming that it is RWD: 379.133 seconds
Assuming that it is Front WD: 400.195 seconds
Now...if we use the downforce and drag figures from that model, but assume the COP is 1.65m and the weight distribution is 45:55 and it is RWD (i.e. the standard KVRC car) we would get a laptime of:
377.158 seconds
Nice!LVDH wrote: To make matters worse some dumb employee must have taken his smartphone to the virtual wind tunnel and leaked the footage of the new car:
http://mantiumcae.com/wp-content/uploads/MR_CP.gif
The thing is... if we went to 4WD then your 50:50 split would work very well... depending on the configuration of the track there would likely be at no disadvantage compared to a rear-biased layout... That is why I still think that the Nissan GTR LMP1 can be an OK solution once they have sorted out the Hybrid system to give them 4WD... I think they should also look at moving the weight bias back from the current 60:40 as I don't see such a bias being very good for the tyres.... and they need to develop a higher downforce package... but that is a separate subject...CAEDevice wrote:I think that with a traditional LMP1 design the front engine solution would not work.
I'm sure that your car, if evolved, could be on the podium. What about the last race?MadMatt wrote:I am following the competition from distance and I must say it looks awesome. No way I could have keep up with you guys. Matteo your Batmobile looks incredible, fair play to you! As for the "rest" I cannot wait to see your evolutions, but in a sense I wish we could see more pictures of the cars, as they are all interesting!
Code: Select all
JJR Racing 68
Variante 58
Mantium RAY 43
CAEdevice 39
TF 24
Brook Motorsport 16
DynaRace 12
Talno Racing 12
Kineuton 10
DH Racing 8
Pure Power Racing Team 7
Mercury Motorsport 4
sjns-Racing 2
Code: Select all
ΔCL.A ΔCD.A Δm from COP=1.65m Δlap time
Mantium RAY +89.175% +18.978% +0.053 -4.117%
Brook Motorsport +70.051% +14.655% -0.437 -2.069%
TF +113.993% +21.849% +0.118 -1.384%
CAEdevice +9.215% +3.509% -0.053 -0.907%
Mercury Motorsport +95.370% +33.036% -0.192 -0.816%
JJR Racing +4.755% +3.165% +0.034 -0.361%
Variante -11.573% -1.149% -0.025 +0.995%
