2021 Engine thread
trinidefender
trinidefender
318
Re: 2021 Engine thread
If they do decide to drop the MGU-H then I hope they allow other technologies that have road relevance.
Mainly thinking variable valve control (lift, duration and timing) and variable nozzle turbine turbochargers.
VNT turbochargers are commonplace in diesels but are reliability limited by the high exhaust gas temperatures in petrol engines (it's my understanding that Porsche had a hell of a time trying to make theirs reliable in the 911). Development in this field will have direct applications for use in petrol road engines. Lastly they will reduce the lag that will inevitably accompany the loss of the MGU-H.
Variable valve control....well I'm pretty sure the benefits of developing that are apparent to everybody
johnny comelately
johnny comelately
110
trinidefender wrote:
18 Apr 2018, 01:07
Just on the turbo subject, koenigsegg seem have a good design but no idea how good it is?
Singabule
Singabule
Koenisegg free valve technology do you mean? It is not reliable yet and cost a lot of energy. F1 dont need something like that, we only need vtec or vvti form.
AJI
AJI
27
Tommy Cookers wrote:
18 Apr 2018, 00:10
petrol-electric it is then !! - with a 1600cc 'range-extender'
That's the most confusing part about the 110kg of fuel for 2019 suggestion?
It can't be a 'range-extender', it can't be an ICE 'power-extender', so it has to be for motoring against the K as an 'E-extender'.
MrPotatoHead
Singabule wrote:
18 Apr 2018, 01:26
Freevalve is also far from being able to run at high rpm aka F1 levels.
I don’t believe they can even run over 6,000 rpm yet.
Singabule
Singabule
MrPotatoHead wrote:
18 Apr 2018, 03:11
Singabule wrote:
18 Apr 2018, 01:26
Spring valve still good untill 13K rpm, unless they want engine to reviving to 15 K or 18K the variable technology cost still bearable. One question, could we design variable desmodromic valve to increase rpm? Also with current pneumatic valve, the timing can be adjusted, but is it possible to adjust lift also?
henry
324
Surely with a turbocharged engine the manufacturers will only run high revs if they are instructed to by regulation. Similarly high cylinder count.
Singabule
Singabule
henry wrote:
18 Apr 2018, 09:09
Yes, the increase in rpm is discussed to improve sound. However there is no further detail how much the increase is, i think 15k still the target from FIA
Xwang
Xwang
29
Why don't they simple say that MGU-H is not mandated and not forbidden so that if someone wants to keep it, he can do?
NL_Fer
NL_Fer
82
Xwang wrote:
18 Apr 2018, 18:01
Honda had an MGU-H which was a little less efficient than the others. They were already sitting ducks on the straight. The cars without will be less powerfull and taking 20kg more fuel at the start.
On the rev, if they keep the fuel flow limiters, i hope they will increase the limit with rising revs. So if it is 100kg/hr, it must be like 100kg at 15000rpm, 80kg at 12000rpm, 60kg at 9000rpm etc...
johnny comelately
johnny comelately
110
Xwang wrote:
18 Apr 2018, 18:01
agreed
AJI
AJI
27
Xwang wrote:
18 Apr 2018, 18:01
With different fuel flow rates and quantity for BoP, maybe...
Big Tea
99
johnny comelately wrote:
19 Apr 2018, 09:41
Xwang wrote:
18 Apr 2018, 18:01
agreed
The thing with this though is the teams could spend huge amounts on developing the units while not even using them.
If it came out of the F1 teams 'cap' if it comes about or if it is factory spend, it is still money used for the F1 program which some will spend and compel a new engine entry to include in the budget.
I still think it should be a V12, nothing sounds better than a V12 IMO.
roon
roon
412
18 Apr 2018, 00:10
Full electric + i.c.e. exhaust noise generator of any cylinder arrangement. Smaller fuel tank limits the dead weight. No mechanical load should allow one engine per season. Relevant to industry trends, while continuing development of nostalgic technologies.
