McLaren MCL32 Honda
Re: McLaren MCL32 Honda
Godius
186
6 element t-wing, via Andreas Haupt‏:
FW17
169
Honda influence
Jef Patat
Jef Patat
mclaren111 wrote:
28 Jul 2017, 07:20
https://youtu.be/FRrsR6KJCuw
Nice video
So it is a small pitot array in front of the rear wheel. (1:35)
GoranF1
GoranF1
155
j2004p
j2004p
FW17 wrote:
28 Jul 2017, 09:37
Honda influence
https://indyracereviewer.files.wordpres ... erocar.jpg
Peak-downforce-tastic!
GoranF1
GoranF1
155
Redragon
19
Flow wiz on the T-wing it would be nice to see a side picture to see the airflow and understand a bit better how it works. Thanks for the pic
KingHamilton01
Can't be sure but if you look closely in that picture, you can see Red flow viz on the rear wing, so I would say the T-wing is Guiding air onto there. Be nice to see someone give us a more in depth analysis though
McLaren Mercedes
the EDGE
the EDGE
67
I thought the idea of the T-wing was to create an upwash I front and above the rear wing in order to aid the upwash of the rear wing
That and it's pretty low drag for the downforce it produces itself.
Jef Patat
Jef Patat
KingHamilton01 wrote:
28 Jul 2017, 18:59
Those are just splatters flying off and hitting the rear wing. Twings are not about guiding airflow. They just create blunt downforce. They actually take away a bit of downforce from the rearwing because of the upwash they generate.
Dipesh1995
Dipesh1995
104
Jef Patat wrote:
28 Jul 2017, 21:53
28 Jul 2017, 18:59
The video shows what a more simple t-wing does. The explanation sounds legitimate.
https://youtu.be/yJ-xdo8Ebzg
Jef Patat
Jef Patat
I'm not convinced the vortex explanation is correct. Most teams have by now have chosen for closed multi element twings. Except for TR I think. I think this is to reduce the number of strong vortices and still have the benefit of downforce. His explanation also doesn't take into account what the vortex would cause under yaw where downforce is needed most.
