Mercedes-AMG F1 W10 EQ Power+
mantikos
mantikos
Re: Mercedes-AMG F1 W10 EQ Power+
turbof1 wrote:
15 Apr 2019, 13:00
ringo wrote:
14 Apr 2019, 22:48
Sevach wrote:
13 Apr 2019, 19:53
Just a little kink to the endplate to comply with the rules, very clever.
For aero purposes it's still exposed and pushes the air out.
I'm thinking Mercedes already saw that ruling coming.
I mean even Red Bull with time to think about it decided to close everything, they can't have come out with that on friday, right?
It's not really a kink. That little piece that was added on is supposed to be a part of the end plate now. So in effect the wing flap would fall behind it when viewed from the side. So it is practically the smallest possible extension of the end flap to appease the rules.
A kink would in the wing element itself would have been illegal infact.
The extension to the endplate has to be part of the original VES itself, and adhire to the minimum/maximum (10mm minimum, 12mm maximum) thickness and edge radii (5mm radius). It looks like it does so.
This is a good example of how to explain the regulations, so I will remember this one (and I might even do an article on it). I do wonder if they can push it more to the edge. Since the solution got outlawed on safety issues, I wonder if they can get the wing element exposed without sharp edges.
I think that's the direction they're going to go to, either move the sharp point inwards and further away from the end plate and end with a rounded section (if they need a vortex there to increase the outwash effect as Scarbs keeps implying), or just end with a rounded section since the only thing that was outlawed was the sharp point end, that's an easy fix. Looking forward to the article.
dans79
267
turbof1 wrote:
15 Apr 2019, 13:00
They probably can, all they really need to know is what the minimum radius is to be considered safe.
201 105 104 9 9 7
dans79 wrote:
15 Apr 2019, 16:47
turbof1 wrote:
15 Apr 2019, 13:00
3.3.6 a) iii) might not allow it. Unless they can dig up a rule that can act as an exception. At the end of 3.3.6. a) the rules allow a 10mm taper radius where the endplate (endplate, not VES!) meets the wing element. If they somehow succeed to get an acceptable intepretation of that to use the taper radius to make the wing element edges safe, it is possible.
dans79
267
turbof1 wrote:
15 Apr 2019, 17:17
dans79 wrote:
15 Apr 2019, 16:47
turbof1 wrote:
15 Apr 2019, 13:00
what copy of the rules are you looking at? I don't see that in the latest revision published 12.03.19
https://www.fia.com/regulation/category/110
201 105 104 9 9 7
dans79 wrote:
15 Apr 2019, 17:50
turbof1 wrote:
15 Apr 2019, 17:17
dans79 wrote:
15 Apr 2019, 16:47
Yeah that's my bad. I was trying to cite the articles from memory, but got the order nummers wrong. It's 3.3.6 b) iii) (page 14) and the part about the 10mm taper radius is at the end of 3.3.6 (page 15).
atanatizante
124
They added some little rake ...
And this is the first time this year when they used again the new rear wheel rims?
Jesus
Jozsusz
Jozsusz
-3
atanatizante wrote:
15 Apr 2019, 20:09
http://postimg.cc/kB31LgVQ
Every car has a rake. But this one is still way below the Renault and RB.
mantikos
mantikos
atanatizante wrote:
15 Apr 2019, 20:09
It looks no different than the previous race, or the first race to be honest.
GrandAxe
GrandAxe
atanatizante wrote:
15 Apr 2019, 20:09
Good catch.
Notably, Lewis had just swerved when that pic was taken.
The rake seems to vary depending on the area of the track - similar to Ferrari diving in corners and squatting on straights during the Barcelona tests. Tellingly, Merc experimented with different wing heights in the first week of that test.
Here is an image from the Chinese gp showing pronounced rake and low front wing from both Mercs while cornering (one braking, the other accelerating):
Credit - AP news.
Here's another showing higher front wings:
Credit Formula1.com
Last one from China, on a straight, showing "normal" Merc rake:
zibby43
zibby43
atanatizante wrote:
15 Apr 2019, 20:09
Just curious, why do you say this was the first time they used the "new" wheels? To my eyes, it looks like they used the same wheels they've used since the beginning of the season.
M840TR
M840TR
315
via Albert Fabrega
GrizzleBoy
GrizzleBoy
Front wing y250 generators more like williams' "blunt" style vs the more common bird beak shape.
Edit: wait, isn't it just the angle?
zibby43
zibby43
GrizzleBoy wrote:
24 Apr 2019, 22:03
According to Albert Fabrega, this spec does indeed have the Y250 section of the flaps trimmed down.
It's easier to spot when you focus on the uppermost flaps (the top 2, in particular).
The image quality containing the Baku spec isn't great.
JasonF1
It does look to be a low downforce wing as well.
M840TR
M840TR
315
JasonF1 wrote:
25 Apr 2019, 04:55
I can't notice anything in the image that suggests low downforce; the flap arrangement is pretty much the same.
