Red Bull RB8 Renault
amouzouris
105
Re: Red Bull RB8 Renault
beelsebob wrote:
amouzouris wrote:i think we are misunderstanding each other!!:P im talking about the hole on the back side of the sidepods...its getting air from the hole in the side... and i was wondering if that could also be a cooling exit for the sidepods....meaning air exiting from that hole could be clean air from the side and air from inside the sidepods...thus increasing the volume of flow at the top of the diffuser
It could be – but I doubt it, their cannon exit above the beam wing seems more than sufficient.
i dont disagree...but what i thought isn't that they need more cooling...just for increased flow to the diffuser...
J-L
J-L
Crucial_Xtreme wrote:
J-L wrote:
Crucial_Xtreme wrote:That starter hole is huge!
right click>view image
The starter hole ???
Where you see it ??
I was commenting on the post above when I replied.
@beelsebob that's what I was thinking. Very complex & elegant solution.
Ok :wink:
beelsebob
beelsebob
85
Timstr wrote:Is my screen that bad? Don't think so.
Take a look at the line I've drawn where the floor meets the side pod, and the circle surrounding the reflection on the flat floor. It's deffinately open
gandharva
252
Timstr wrote:
beelsebob wrote:
Timstr wrote:Slot closed here:
Optical illusion – that slot's open.
It's open in both pictures.
Crucial_Xtreme
Crucial_Xtreme
404
As someone once told me: When in doubt, it's probably a reflection, shadow or other optical illusion. I promise
I know it looks closed, & it's hard to tell your eyes it's not seeing what it think it is, but.
@bhall :p
Timstr
Timstr
Ok then. My laptop screen is not optimal, so I accept what everyone is saying.
Forza
238
Yes it's optical illusion created by reflection from that shiny floor coating thats why you can't see the tunnel.
cirrusflyer
amouzouris wrote:
Crucial_Xtreme wrote:Hrmm..
looking at it from this angle..the hole is massive!! VERY VERY good job from red bull! AGAIN!!
Ahmm! Nice holes yes...but do you guys see the rake?! This is huge and AN lied about they are lovering back of the car.
If flying were the language of man, soaring would be its poetry.
It's all about technology!
When you go fast, do not hesitate to go faster!
Lurk
I was thinking about something more complex about exhaust fumes route.
It feeds partly central diffusor channel thanks to the massive starter hole or wathever it is & partly the side of the diffusor same as last year. Would it be possible?
MIKEY_!
I was thinking much the same thing. It could only work at high speed. Could the exhaust fire at the brake duct fins at low speed then move to the diffuser as the down-wash from the sidepods increases at speed?
beelsebob
beelsebob
85
Lurk wrote:I was thinking about something more complex about exhaust fumes route.
I doubt that one, because it involves flowing across a painted area of side pod – that seems to suggest that the exhaust is pushed off the edge and "jumps" the air flowing around the pods.
Forza
238
After the whole day of running the exhaust fumes will leave some trace on the bodywork so we will be able to predict where they flow.
Timstr
Timstr
To me it looks like they're attempting to split the exhaust flow. Towards the edge and the centre of the diffuser.
AnthonyG
38
http://www.formula1.com/wi/sutton/2011/dms1203ma31.jpg
Why is the slot on top of the sidepod open on the right, but closed on the left?
(first time poster so sorry if this allready was asked somewhere)
siskue2005
70
Is it really legal to channel the exhaust like rbr are doing now?
The rule clearly states that you can't channel the exhaust #-o
