bhall II wrote:timbo wrote:FWIW cars are set up in a way to avoid such situations.
Except when they're not. For example...
Now my turn to call apples and oranges. We're talking cornering.
bhall II wrote:Anyone notice how Ferrari's tire tester is equipped with side skirts along the flanks of the floor but not along the edges of the diffuser? There's a reason for it.
http://i.imgur.com/HVhhP5W.jpg
There might be
reasons for it. And not all might be aerodynamic. Actually, the floor before the rear wheels is simply wider than the inner side of the tyre. But yeah, the interaction of the flow along the diffuser with significant lateral component with a skirt might be tricky.
bhall II wrote:So, if we know that literally sealing the diffuser can be problematic, what should we expect if the ride height of a diffuser's footplate is drastically reduced and the ride heights of its inner strakes and VGs are completely eliminated? What role is greatly reduced dynamic pressure likely to play given angles that would ordinarily offer feast or famine as a function of ride height?
Can you map these angles? If you can you can sell them to RBR or Ferrari. Just don't use third party copy services.
bhall II wrote:(Incidentally, if Rosberg's front wheels aren't indicative of a car that's mere nanoseconds away from being driven straight ahead, then what does it really mean to drive straight ahead? I need to know, because I don't know that I can deal with yet another existential crisis.
In my book, both his front wheels AND his position on track (where's the outside kerb? especially if he's @ Degner) are indicative of a car which is still a long way from driving straight. Being past the apex does not mean you're not pulling lateral G's that normal car NEVER could reach.
bhall II wrote:In my view, what we can see in the photo is an anomaly that likely represents a very bad moment for the floor.
I agree that it might be anomaly, but not necessarily that bad. This is something the car could deal with because we know a) nothing was apparently broken (no reports) b) there were no major "moments".
bhall II wrote: However, since racing is always relative, I think any net penalty is easily forgettable, because the difference between acing that corner and completely screwing it up is all but negligible as long as nothing gets broken.
My point that completely screwing a corner (result from total loss of underbody DF) would mean an excursion to gravel at the very least.
Here's picture from the onboard of Rosberg's pole lap, he's just past the apex at Degner.
Note the steering wheel and especially sparks from the outside endplate of the FW.
