2021 Engine thread
MrPotatoHead
Re: 2021 Engine thread
Singabule wrote:
18 Apr 2018, 01:26
Koenisegg free valve technology do you mean? It is not reliable yet and cost a lot of energy. F1 dont need something like that, we only need vtec or vvti form.
I just saw the comment you were replying to - he was talking about the Koenigsegg turbo valve.
Essentially a Quick Spool valve that is built into the turbo housing (3D printed) that when closed reduces the apparent AR of the housing thus decreasing turbo spool time.
MrPotatoHead
Singabule
Singabule
Wow thanks, this is new product from them, i dont know this is exist before. So basically twin scroll turbo with variable valve between one and other scroll to reduce back pressure utilizing 3D print technique on steel. It should be more reliable than variable vane because fewer moving parts inside the turbine. Yes i agree this could reduce lag, however in expense of reliability and turbine aerodinamics. I prefer use old big turbine with greater efficiency and fill torque using MGUK
MrPotatoHead
Yeah it’s basically a built in version of this:
https://www.suprastore.com/spquspva.html
FW17
171
I do not understand why the engine formula for 2021 is being closed out now, with the dead line set as May 2018
What is the point of giving manufacturers close to 2.5 years? This is just too much of a commitment for manufacturers.
Ideally it should be done in December 2019 so that they have just 12 months and manufacturers who are committing late are not disadvantaged.
CriXus
CriXus
95
60% Efficiency ICE without Hybrid System
“The reasonable man adapts himself to the world: the unreasonable one persists in trying to adapt the world to himself. Therefore all progress depends on the unreasonable man.” - George Bernard Shaw
tcooper27
tcooper27
FW17 wrote:
23 Apr 2018, 15:38
Budgets are one reason. Most companies that are big enough to have the spare cash to compete plan for this kind of ongoing expenditure years in advance. Very few companies are going to commit late to a $150+ million/year project.
CriXus wrote:
23 Apr 2018, 16:29
https://www.youtube.com/watch?v=pCr6bjQMrgU
I posted about this engine last year 8) glad he made a video about it.
https://www.youtube.com/watch?v=6VoiD4P ... IfVB5DoYYp
Here Rolf Reitz(one of the main brains behind this engine) gives his week long lecture explaining his work on RCCI in excruciatingly boring detail. Lots of good insights if you manage to sit through it all the way. He goes over the CFD used in developing it, the things they found, the models used, etc. Just the CFD aspect and the modeling was the most eye opening stuff.
FW17
171
tcooper27 wrote:
23 Apr 2018, 17:52
FW17 wrote:
23 Apr 2018, 15:38
It is too much of a head start to current manufacturers.
We still don't know the details about the engine. Even if it's a turbo V6 I still think the engine block, and rods should be standardized, let the manufacturers figure out the heads crank and pistons, and the lower block. Standardize the cam phasing mechanism and allow variable timing,but no variable lift profiles. Variable geometry turbo and exhaust. Standardized pneumatic valve system. This along with chopping the MGU-H should make the engines substantially cheaper, but still allow the manufacturers to put their own take on the concept. The engine should make roughly ~730hp or like the old V8 engines, the hybrid system should be good for 200+kw. Deployment and recovery should be controlled by the driver, the rate of both deployment and recovery should be variable.
One way would be to have two wheel mounted triggers which deploy through the front wheels. Or a push to pass with different settings, and a BBW which harvests at the rate the driver selects if the plan is to keep it RWD.
CriXus
CriXus
95
godlameroso wrote:
23 Apr 2018, 19:06
I do not understand why no one is mentioning some kind of push to pass. Let's say from these 200kw in the race you have 150kw + 50kw available for some time.
CriXus wrote:
23 Apr 2018, 20:03
godlameroso wrote:
23 Apr 2018, 19:06
Well seeing as how the next gen formula E cars have 200kW race motors, F1 should also have 200kW KERS units. So I agree if the push to pass is 250kW :twisted:
NL_Fer
NL_Fer
82
But how to charge the ES for those push to pass actions? With brake harvesting alone, there will be less than 10s “kers boost” available per lap.
AJI
AJI
27
NL_Fer wrote:
24 Apr 2018, 00:00
Remove down force so they have to use the brakes more?
Motoring against the K is another way, but that seems counterintuitive to me
MrPotatoHead
NL_Fer wrote:
24 Apr 2018, 00:00
The same way they do in LMP - by using the front axle as well as the rear axle to harvest.
