Ferrari SF23
Andi76
Andi76
431
Re: Ferrari SF23
S D wrote:
29 Mar 2023, 18:40
Xwang wrote:
29 Mar 2023, 16:01
Longitudinal loads transfer?
If I understand correctly, Longitudinal load transfer causes the CoG (center of gravity) of the car to move forward and down on braking and the opposite in accelerating. So during braking there will be more load on the front tires and in accelerating more load on the rear tires.
It can also change the effect on the aerodynamics as the air is passing over, around and under the car. So this is why you need to operate with a stiffer suspension in order to counteract the unwanted movement. Is this correct?
So if this is the top issue for SF23 does anyone know if the concern is under braking, accelerating, at low or high speed, cornering or all of the above?
Well, actually, some "dive" was positive, at least in the past. The front wing came closer to the ground and produced more downforce, which was positive when braking, conversely it increases traction when the rear sinks when accelerating. With the ground effect cars, the relationship has changed and the car must not dive too much either front or rear, otherwise the advantage turns into a disadvantage as it can negatively affect the Venturi tunnels and shift the balance adversely, making the car unstable.
Re: Ferrari SF23
Edit: incorrect
Slightly modified outer floor fence shape for this weekend
Spotted by Dr_obbs on Twitter
jambuka
jambuka
Re: Ferrari SF23
30 Mar 2023, 21:10
https://i.imgur.com/muFtrmv.jpeg
Isn't this the one they tested at Jeddah FP1 but did not use it further ?
gordonthegun
254
Re: Ferrari SF23
30 Mar 2023, 21:10
I can't see any difference (considering the different angle of the shot).
Can you give some more detail, please?
Re: Ferrari SF23
30 Mar 2023, 21:10
It's not that long and the shape is pretty much the same, the photo just happened to align with the splitter.
Re: Ferrari SF23
Sevach wrote:
30 Mar 2023, 21:45
30 Mar 2023, 21:10
Oh yes, indeed
Scarbs agreed with the original twitter user so I didn't give it a second look :D
Re: Ferrari SF23
Jesus, every schmuck with a twitter acc is now an expert F1 upgrade spotter...
Re: Ferrari SF23
Underside of the nose/FW
vorticism
323
Re: Ferrari SF23
+1 Sevach. Looks like a v-shaped belly on the nose.
𓄀
Vinlarr89
Vinlarr89
Re: Ferrari SF23
Do we actually know what mods apart from the floor have been brought to Aus? Thought they might have brought a new front end? Unless they’re holding off for Imola
jambuka
jambuka
Re: Ferrari SF23
Vinlarr89 wrote:
30 Mar 2023, 22:56
I read somewhere it will be Jeddah spec car. Only change will be the new floor which they previously tested at Jeddah in FP1, they will run it all weekend. Let’s wait for the upgrade list to be sure.
gordonthegun
254
Re: Ferrari SF23
Vinlarr89 wrote:
30 Mar 2023, 22:56
None visible.
MTL79
MTL79
Re: Ferrari SF23
Carlos Sainz mentioned there were no changes coming for Australia.
catent
Re: Ferrari SF23
MTL79 wrote:
30 Mar 2023, 23:49
I read elsewhere that Leclerc said the same thing. Seems Baku will be the first place we may see significant upgrades/changes, and those could (and likely will) continue through the following 4 races (Miami, Imola, Monaco, Spain). Fingers crossed those changes are positive.
gordonthegun
254
Re: Ferrari SF23
End of floor edge in FP1:
