Red Bull RB19
230
Re: Red Bull RB19
There is a metal skate on the 8nner most turning vane under the floor.
Suggesting the inner section of the floor is cominh to ground?
scuderiabrandon
102
Re: Red Bull RB19
ringo wrote:
21 Jul 2023, 23:57
Potentially but I dont't think this is the case here. Additive manufacturing (3D printing) is used to create complex parts, with sharp edges, which otherwise couldn't be done with carbon, in a much shorter period of time.
This is why it is seen on wing tips, beam wings, front wing endplate joints where the wing elements join the endplate. Also on floor edge wings but in that case I could see it also being used for ground impact protection.
RB16 had 3d printed serated diffuser edge which were later converted to carbon fibre
atanatizante
115
Re: Red Bull RB19
A little bit obvious, isn`t it?
Jesus
atanatizante
115
Re: Red Bull RB19
1. Sidepode belly looks shrink to me compared to the floor edge, maybe due to radiators repositioning
2. Undercut has more curvature thus more airflow attachment?
3. That kink at the leading edge of the Venturi channels entry is new?
Jesus
scuderiabrandon
102
Re: Red Bull RB19
atanatizante wrote:
22 Jul 2023, 12:17
http://postimg.cc/f3523tKq
The diagonal corner is an effect of having the leading edge of the SP inlet at the limit of the reg box. It is not something MB invented. In fact AMR22 launch-spec was the first car to have the diagonal corner due to full length sp inlet
Different length sp inlets, aka underbite was also something RB had on the RB18 at launch. The SF70H actually ran this back in 2017
LeveragedTiger
Re: Red Bull RB19
The more Red Bull develop their concept, the more I interpret it as the inverse of Mercedes’ original zero-pod concept.
The original zero-pod concept was about getting as much air-flow to the rear corners of the diffuser and floor as in theory, that would result in the greatest airflow through the floor thus maximizing overall downforce. The difficulty is that much unconditioned airflow over the top of the floor is far too unpredictable to consistently generate maximum downforce.
In contrast, it appears that Red Bull are maximizing as much airflow over the front of the floor as possible. As a non-aerodynamicist, my speculation is that the benefit of this approach is:
1) creating more downforce at the front of the floor, positively impacting the centre-of-pressure to create a more neutral balance
2) the undercut receiving far more clean air that can then be conditioned by the bodywork for more predictable behaviour at the rear of the car, thus improving the consistency of the floor downforce
BlueCheetah66
BlueCheetah66
Re: Red Bull RB19
LeveragedTiger wrote:
22 Jul 2023, 22:43
I see it more as the opposite. If Red Bull wanted to get more to the front of the floor, they would have gone with a concept similar to Ferrari's from last year, creating a higher pressure zone at the front of the floor. The undercut is more to direct air to the rear floor edge and the the rear corner. You could see from the start of the season when they applied flow viz how clean the flow was to this region.
By contrast, I think that the Mercedes Zero-pod was more aimed directing air towards the front of the floor edge and getting clean air to the beam wing region.
230
Re: Red Bull RB19
The redbull side pod does 3 things. The zero pod was doing maybe 1 thing.
The redbull concept conditions air to the floor edge with the outwash, it reduces drag by interacting with the front wheel wake as we see with the bulges. This also sheilds this same wake from going to the diffuser. That stepped outwashing shape on top of the sidepod also does this by pushing air into the wake and this also modifies the flow to the rear wheels.
The top of the sidepod now does the classical pressure recovery to mitgate lift but also bring clean airflow to the diffuser and midwing.
The zero pod lacked mainly on the floor edge flow enhancement and protecting the downstream from the turbulence of the wake and provably even yaw effects.
Re: Red Bull RB19
Current (new as of Hungary):
The image doesn't do the complexity of the 3d shapes justice.
📸 f1tv
Old high cooling brake front duct outlet:
Ben31
Ben31
Re: Red Bull RB19
Revised coke/engine cover
Cs98
Cs98
Re: Red Bull RB19
Ben31 wrote:
28 Jul 2023, 12:46
Would need a comparison to see the difference.
lio007
316
Re: Red Bull RB19
This is from last weekend. Unfortunately not the same camera angle, but when you look at the wishbones you can see the new one is a little bit smaller.
Cs98
Cs98
Re: Red Bull RB19
lio007 wrote:
28 Jul 2023, 13:11
Probably just different cooling options.
Re: Red Bull RB19
Yes just lower drag config for spa/Monza/Vegas prob
Not the best angle or anything but best I can do
Much smaller gap between the panels where the upper wishbone inserts
Ben31
Ben31
Re: Red Bull RB19
