Zynerji
110
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
Quick question on the current regs.
Is it illegal to use the air system from the pneumatic valves to actively flush the prechamber?
Dr. Acula
Dr. Acula
46
Zynerji wrote:
24 Mar 2021, 19:11
I would say, yes it is.
Though the pneumatic valve system isn't specifically mentioned, i think it would violate this rule.
5.14.1 With the exception of incidental leakage through joints or cooling ducts in the inlet system (either into or out of the system), all air entering the engine must enter the bodywork through a maximum of two inlets which are located:
a. Between the front of the cockpit entry template and a point 500mm forward of the rear wheel centre line longitudinally.
b. No less than 200mm above the reference plane vertically.
c. On vertical cross-sections parallel to C-C. Furthermore, any such inlets must be visible in their entirety when viewed from the front of the car without the driver seated in the car and with the secondary roll structure and associated fairing removed (see Article 15.2.6).
5.14.2 The addition of any substance other than fuel, as described in Article 5.10.3, into the air destined for combustion is forbidden. Exhaust gas recirculation is forbidden.
Zynerji
110
If the pneumatic valve air was taken from the plenum, post turbo, it could technically be compressed and used for valve springs, then purged into the combustion chamber, through the prechamber, during the exhaust stroke (obviously not combustion air then). Also, it could still be considered the same combustion air that entered through the proper method, it just takes a different route to get into the chamber.
I think it could be a thing...🤔 Unless it specifically states that all combustion air must enter through the intake valve...
hurril
hurril
Zynerji wrote:
24 Mar 2021, 23:11
I think it says something like that. And that there are only ever four valves, so whatever that is entering the pre-chamber, it won't work.
Zynerji
110
hurril wrote:
24 Mar 2021, 23:26
Zynerji wrote:
24 Mar 2021, 23:11
It would interesting to find a hard answer. Even the injectors already run 2 fuel inlets (high-temp + low-temp) so they can mix for best fuel temp in the chamber. Why not add a third and push air through it as well? Its not busy injecting fuel during the exhaust stroke..
Singabule
Singabule
hurril wrote:
24 Mar 2021, 23:26
Zynerji wrote:
24 Mar 2021, 23:11
They could bleed the valve into precamber, so prechamber will shut the last compared to the cylinder. This would mitigate soot build up inside prechamber. The most tricky is how to use single injector for both cylinder and prechamber, so I still believe they design 2 injector into one, with completely separate timing and volume to create workaround from the regulations.
Singabule
Singabule
There are several mistery arround these engine, and I think of probable answer for each issue:
1. The prechamber inlet valve. By the regulations, engine should have 4 valves. So you can use one of intake valve as part of prechamber itself, so it may thicker compared to the another one to create sideway sealing needed to seal the prechamber. So the prechamber would be letter L and become I when the valve shut. Due to temperature constraints on prechamber, it could be controlled by sodium filled valve.
2. The injector. It is placed on exhaust side with 2 different side of opening, a few hole, and 2 separate function, one the main chamber, one the prechamber,ans build into one casing as per regulation says. There could be a few injections per cycle, but the target would not to build evenly AF mixture, but to create pocket of air beside the cylinder wall so there would be minimum heat loss. The challenge would be too rich (remember Honda 17 issue, why produce fewer HP than its predecessor).
3. The tubling effects/swirl. The current generation of engine need the least disturbance and swirl as possible, so contrary to the diesel engine for the reason I state in number 2.
4. The cylinder deactivation and ALS. This is very pronounced in honda compared to others, as solutions of electricity deficiency issue. This would sacrifice fuel but could maintain the turbo keep spooling without wastegating, partial open into butterfly or individual cylinder valve, or any strategy and trick into braking and cornering. The idea is to reduce pumping loss as low as possible and the sampe time to create positive pressure on the exhaust. Also this strategy may help the exhaust from taking the abuse from temperature differential if only relying on cold blowing.
566
I think its good to throw ideas around but you are probably overthinking this.
1. Do some research on Mahle TJI and you will see that pre-chamber flushing is not required or beneficial.
2. A high pressure direct injection nozzle is a very sophisticated piece of cutting edge technology. It is unlikely that the extra complexity you are suggesting would be undertaken - especially considering there are much simpler ways to meet the requirement. viewtopic.php?p=849364#p849364
3. Tumble/swirl. Depends on the degree of main-chamber stratification required. Remember the rich PC, lean MC is already a rich/lean burn system. I would imagine some swirl might be useful if some degree of radial stratification was desired. If no MC stratification is desired, tumble and or swirl would be useful to homogenise the MC charge.
Bandit1216
21
About pneumatic valve "springs' fed by the turbo; Aren't we missing the fact that it's actually nitrogen at 250 psi orso. "only" 3 bar of turbo pressure would make the piston of the valve spring way too big. Bigger then the bore of the engine.
NL_Fer
NL_Fer
82
Has there been any thoughts about how the power output can be influenced without changing the engine maps. Could it be possible to use some sensor input to “detect” conditions were a flying lap is started or the first lap of the race.
Changing maps is not allowed, but when such characteristics are built inside a mapping, it is allowed.
flmkane
flmkane
Re: Formula One 1.6l turbo engine formula as of 2013
joseff wrote:
13 Dec 2010, 05:35
Okay, how about autogyro's idea but with mechanical coupling?
So you have the turbine on the exhaust side, then a propshaft going through the engine, probably through the crankcase. The compressor is then on the intake side.
The intercooler goes on top and fed by the usual roll hoop ram intake
Benefits:
- shorter exhaust manifold
- shorter intake path
- vertical cylinders (better in terms of wear?)
- smaller footprint like a 2.4 V8
This guy back in 2010.He was a goddamn genius. Isn't that what Merc did to an extent?
aleks_ader
90
NL_Fer wrote:
29 May 2021, 14:57
Hmm i really like your train of thoughts. Some sortish sub branching in mapping. Mann. i guess small "mini Ai" algorithms are at play also. At least in driver in loop simulations i would think.
I guess hybrid system nowadays makes job for FIA that almost impossible. How you are are gona to catch on such acts of indecency. How they dare to fool us. :D Anyway. Also would be perfectly legal. I trough those years in interviews from Allison, @amazingWazzariSan, Cowell and even Marmorini, Binotto got the impression that those v6 PUs nowadays act much more at its own accords constantly. SYSTEM that acts from local moment and adjust to the best overall lap time (lets say overall maximums) that is predicted and simulated beforehand. So from corner to corner from ENTRY, MID, EXIT independently from previous lap even. That variations are unavoidable because it depends on witch session/part of race is on atm, fuel always goes down, traction starts braking (tire deg, conditions of surface), derating of components, air condition changes (even dirty hot air). Soyeah its quite a feed and complex engineering. Juggling at minimum 6 separate PU entities at its owns brings huge mapping problem. Don't to mention that drivers wants consistency from corner to corner, lap after lap.
aleks_ader
90
flmkane wrote:
08 Aug 2021, 11:31
joseff wrote:
13 Dec 2010, 05:35
Benefits:
Heh i remember sketches of one guy who drew that, Or was even him. Yeah in concept Merc did exactly that. Maybe he is now Merc engineer or some other Merc engineer got idea from him HAHA. I guess he needs some pile of cash on its account for that domination. heh
NL_Fer
NL_Fer
82
aleks_ader wrote:
18 Sep 2021, 14:07
NL_Fer wrote:
29 May 2021, 14:57
Looking at the fumes of dry ice on the starting grid this weekend, it remembered me about this. It think it is pretty easy to cool certain sensor readings in an area for one or two laps. Than have an ICE mapping were the powerunit gives more power, as long as the sensor is kept cool. Gives the car a little more performance each qualifying session and at the first few race laps.
Zynerji
110
Bandit1216 wrote:
10 May 2021, 10:21
It could go from the 45ishPSI turbo outlet into another compressor for the 250PSI boost, then it satisfies the word of the regulations.
