Ryar
Re: 2014-2020 Formula One 1.6l V6 turbo engine formula
NL_Fer wrote:
29 May 2021, 14:57
Has there been any thoughts about how the power output can be influenced without changing the engine maps. Could it be possible to use some sensor input to “detect” conditions were a flying lap is started or the first lap of the race.
Changing maps is not allowed, but when such characteristics are built inside a mapping, it is allowed.
The conditions that you are talking about, can be fuel level? What restricts a piece of software (an engine map) to read the fuel level and accord the power output? In quali, when the car is fueled light, the software can run more aggressive internal map (one of the subsets of configurations in an engine map) and at the start of the race, it can run a different, conservative one on the basis of heavier fuel load. None of it requires a manual input from driver. Is there a rule that explicitly stops such a circumvention?
Hakuna Matata!
ENGINE TUNER
ENGINE TUNER
26
NL_Fer wrote:
29 May 2021, 14:57
Simple. The driver presses the overtake button on the steering wheel which gives them max output for as long as they are WOT. Listen to HAMs radio right before they restart the Abu Dhabi farce, Bono tells him that he has overtake.
The overtake button signals the ecu to override the current engine mode setting and instead use the maximum output setting.
568
So near the end of the race as the fuel load lightens it goes into the aggressive mode?
saviour stivala
saviour stivala
52
gruntguru wrote:
16 Dec 2021, 10:02
But isen't going into an agressive 'mode' a change of power unit map selected and approved to race on?.
Ryar
gruntguru wrote:
16 Dec 2021, 10:02
Which is good right? Atleast in the current circumstances everyone would be trying to go for the fast lap point at that stage. With the current reliability of the engines, they can do a couple of more "quali" laps at the end of the race.
Besides, you can code a variety of combinations in the software to accurately to control it. For example, you can add a counter in the software that can record the number of laps done (or mileage in race?) and use that as an additional parameter for decision making parameter about enabling/disabling the aggressive configiruation. You don't do more than 100 kms in quali (Q1 to Q3) Vs more than 300 kms in races. If the counter reads >300, then don't enable the aggressive mode even if the fuel remaining is < 10kg.
switch(mode) {
case remainingFuel < 10kg && mileageDone <100:
enableQualiMode();
break;
case emainingFuel < 10kg && mileageDone >100:
keepRaceModeOnly()
break;
default:
// code block
F1 engineers are really smart people and who knows, probably we are way too late to this party! This might already be happening, quietly.
Hakuna Matata!
sosic2121
sosic2121
Re: Formula One 1.6l turbo engine formula as of 2013
flmkane wrote:
08 Aug 2021, 11:31
joseff wrote:
13 Dec 2010, 05:35
Okay, how about autogyro's idea but with mechanical coupling?
So you have the turbine on the exhaust side, then a propshaft going through the engine, probably through the crankcase. The compressor is then on the intake side.
The intercooler goes on top and fed by the usual roll hoop ram intake
Benefits:
- shorter exhaust manifold
- shorter intake path
- vertical cylinders (better in terms of wear?)
- smaller footprint like a 2.4 V8
This guy back in 2010.He was a goddamn genius. Isn't that what Merc did to an extent?
Wow
I think he deserves an upvote :D
Ryar
sosic2121 wrote:
17 Dec 2021, 14:08
flmkane wrote:
08 Aug 2021, 11:31
joseff wrote:
13 Dec 2010, 05:35
Benefits:
Wow
Honestly, I feel more like he is a time traveler and put this post by going back time! How can he be so close to an all time hit engine design idea, four years before Mercedes did this! Amazing. =D>
Hakuna Matata!
henry
324
In the most recent regulations, 15 Dec 2021, they have slipped in another restriction
5.2.14 The power unit may be equipped with a maximum of two wastegates and two pop-off valves.
Anyone any theories as to why this needs controlling?
NL_Fer
NL_Fer
82
ENGINE TUNER wrote:
16 Dec 2021, 06:00
NL_Fer wrote:
29 May 2021, 14:57
I doubt if that is allowed. Overtake button is probably only for deployment of the ERS battery. So it will override any pre-programmed deployment schedule and give full deployment, until released or empty battery.
ENGINE TUNER
ENGINE TUNER
26
NL_Fer wrote:
24 Dec 2021, 18:09
ENGINE TUNER wrote:
16 Dec 2021, 06:00
NL_Fer wrote:
29 May 2021, 14:57
Do you know a regulation that disallows max output with overtake button?
saviour stivala
saviour stivala
52
NL_Fer wrote:
24 Dec 2021, 18:09
ENGINE TUNER wrote:
16 Dec 2021, 06:00
NL_Fer wrote:
29 May 2021, 14:57
Yes. fully agree that overtake button deploys 'ERS battery'' full battery power in store. it does not change power unit mapping selected and approved to race on. Full battery power can be used in two ways, the first way is deploying full MGU-K power permitted by rules, and the second way is full battery power can be shared by MGU-k and MGU-H (both in motoring mode) with the waste gate/s open (electric supercharger mode).
aleks_ader
90
Ryar wrote:
18 Dec 2021, 18:22
sosic2121 wrote:
17 Dec 2021, 14:08
flmkane wrote:
08 Aug 2021, 11:31
Wow
Some words from Merc almost confirmed that they found idea from outside. I guess some Merc engineer saw that here and pitch the idea to Cowell. Back in 2014 we all were humbled and dumbfounded how genius his pitch was. =D> I pitched stupid idea of overhead exhaust LOL Witch Ferrari sorta emulated and ditched after 1st season LOL
Zynerji
111
henry wrote:
24 Dec 2021, 17:02
Controlled, pressurized air could be used for aero benefit if not contained I imagine...
6 BoV's aimed at the diffusor might be helpful! 😂
Big Tea
99
Zynerji wrote:
31 Dec 2021, 20:16
henry wrote:
24 Dec 2021, 17:02
Is there any way it could be used to warm rear tyres?
mzso
mzso
65
aleks_ader wrote:
31 Dec 2021, 20:01
Ryar wrote:
18 Dec 2021, 18:22
sosic2121 wrote:
17 Dec 2021, 14:08
Wow
By the way. He was talking about vertical cylinders. Was it still supposed to be straight fours at that point in 2010?
