Mercedes W11
holeindalip
holeindalip
Re: Mercedes W11
PlatinumZealot wrote:
12 Mar 2020, 14:58
Looks hydraulic Assisted from different points? Quite a big peice of kit.
Wait a minute! i Don't see no steering rack!
https://pbs.twimg.com/media/ES4XV0JUMAI2R1p.jpg:large
I wonder if the whole setup is hydraulic and pushing/pulling the wheel just pushes/pls the hydraulic fluid in the cylinder ends
Sieper
73
Re: Mercedes W11
I think the whole thing is motor driven and hydraulically operated on the push of a button, the steering wheel just moves in and out as a consequence of that part of the steering geometry moving back and forth as a unit (that is what changes the toe out to neutral, a part of the suspension being pulled backwards).
Re: Mercedes W11
Pretty much expected it to be hydraulic assisted when we first started talking about it given how smoothly it moves - if it uses the same hydraulics as the rack itself and a spool system so it's just 'assisting' the hand inputs it's perfectly legal.
izzy
izzy
Re: Mercedes W11
god is that whole huge thing DAS? i was thinking it'd be like a steering rack just fatter! No wonder RBR want it banned cos it doesn't look copyable whatsoever for this year
Re: Mercedes W11
Like I said before, copying it is easy, fitting into your existing packaging for the year....not so much.
e30ernest
e30ernest
27
Re: Mercedes W11
I wonder how much of a weight penalty that would be. I mean, the longer wheelbase would probably mean they have more leverage balancing to the rear, but that's still a fair amount of mass far up front.
Re: Mercedes W11
via @NicolasF1i
dans79
267
Re: Mercedes W11
MtthsMlw wrote:
12 Mar 2020, 17:07
https://pbs.twimg.com/media/ES6obHcXgAU ... name=large
via @NicolasF1i
This is a perfect example of why Mercedes has been so dominant, They seem to have every possible eventuality covered.
201 105 104 9 9 7
izzy
izzy
Re: Mercedes W11
MtthsMlw wrote:
12 Mar 2020, 17:07
via @NicolasF1i
haha, a snap-on cover they made earlier :D
izzy
izzy
Re: Mercedes W11
dans79 wrote:
12 Mar 2020, 17:28
MtthsMlw wrote:
12 Mar 2020, 17:07
via @NicolasF1i
so true!
mmred
mmred
-3
Re: Mercedes W11
dans79 wrote:
12 Mar 2020, 17:28
MtthsMlw wrote:
12 Mar 2020, 17:07
via @NicolasF1i
It s also an example of already knowing the solution Is questionably legal , then deemed illegal, but putting It on track Just the same.... Other teams, even top teams, wouldnt spend so much for that extra design and production. But Mercedes can afford it
Re: Mercedes W11
mmred wrote:
12 Mar 2020, 17:36
dans79 wrote:
12 Mar 2020, 17:28
MtthsMlw wrote:
12 Mar 2020, 17:07
via @NicolasF1i
Ferrari and RedBull can afford it too. They have chosen to spend it elsewhere.
matt_b
matt_b
Re: Mercedes W11
MtthsMlw wrote:
12 Mar 2020, 17:07
via @NicolasF1i
Not an ideal solution, looks more like a temporary fix but I am sure they will have one for the next event.
Re: Mercedes W11
gandharva
252
Re: Mercedes W11
matt_b wrote:
12 Mar 2020, 18:15
MtthsMlw wrote:
12 Mar 2020, 17:07
via @NicolasF1i
Back view:
