But Wesley123, ask yourself this.
Is the wing moveable. Yes.
Is the wing Aerodynamic. Yes.
Is the wing a device. Yes. Because it moves.
Therefore it breaks rule 3.15.
I like this analogy, it makes sense.wesley123 wrote:it is sort of similar as active suspension
Now only if you could define for us, the mere mortals, how much is "too much" ...HampusA wrote:...................
if they get past that and still have a wing that flexes to much there will be further, more advanced tests but since the sensor test measures real world movement of the wing at top speed it should gives as very exact numbers on how much the wing flexes.
Dragonfly wrote:Sorry, but a car is built and measured respective of the reference plane, not the floor.
