WEC 2020 Tech Regulations - Hypercar Regulations
Holm86
245
Re: WEC 2020 Tech Regulations - Hypercar Regulations
geraldix
geraldix
Great article on the Peugeot 9X8 design:
https://www.dailysportscar.com/2022/01/ ... ercar.html
Capeta
Capeta
Any chance they try rear wheels smaller than front wheels with thoses tunnels inside ?
Stu
Capeta wrote:
19 Jan 2022, 20:25
Like Nissan tried? I think that tyre sizes are mandated depending on whether cars are 4WD (hybrids) or RWD (LMDh or ICE only).
jjn9128
770
Tyre dimensions are fixed but they have 2 options on front and rear widths.
Front Tread | Rear Tread | Tyre diameter | Wheel diameter | Front wheel | Rear wheel
1-> 310mm | 310mm | 710mm | 18" | 14" | 14"
2-> 290mm | 340mm | 710mm | 18" | 13.5" | 15"
#aerogandalf
Capeta
Capeta
In the technical regulation : https://www.fia.com/regulation/category/118
There is a maximum width and tires dimensions. No minimum.
That's where my reflexion come from.
Thanks for the answers.
Gilles27Kimi7
Gilles27Kimi7
25
The options effectively supplied by Michelin are just
1) was designed for AWD, 2) was initially supposed to be the RWD tyre size, but in 2021 only 1) has been used by both Toyota and Glickenhaus. From 2023 the 2) option will be mandatory on new AWD LMH homologations, and it is supposed that Peugeot actually uses the larger rears. LMDh will also use 290|340.
MrMuffins
MrMuffins
Cadillac has shown the first footage of their LMDh for IMSA and Le Mans in 2023
It is definitely different from their DPi
Pandamasque
vorticism
323
Fluido wrote:
12 Apr 2022, 22:03
Maybe this toys can show undertray?
https://www.cdn-docs-ck.com/docs/bilde ... 309805.jpg
LMP cars had a spec undertray for maybe a decade or more. Nothing complex, two simple tunnels with a flat floor and plank. Lopez' crash in Sebring revealed the current Toyota hypercar hasn't strayed too far from it.
𓄀
Fluido
Fluido
vorticism wrote:
12 Apr 2022, 22:16
Fluido wrote:
12 Apr 2022, 22:03
Yes, problem with specs undertrays is best for given regulation, so this is not best example how undertray must looks.
This is why is best to look at cars without constrictions, Pikes peak(IDR), Vlkryie etc..
F1NAC
164
Are there any news regarding Ferraris hypercar? There should be already a prototype kicking around?
Found an article from February that says that the new hypercar will debut on track at Fiorano this month.
'Tis me, just me.
'Tis me, just me.
F1NAC wrote:
06 Jun 2022, 15:03
I guess we'll find out soon enough if it's this month. Also why were ByKolles not allowed to take their car racing this year?
