Emag wrote: ↑24 Mar 2024, 22:51
Unfortunately, it's not even about the last two corners, it's just the penultimate corner. With the downforce these cars have, the last corner is pretty much flat at those speeds.
But the performance at the penultimate corner is pretty bad.
Below is the comparison between two very similar laptimes on the last stint between Lando and Charles and Lando takes ~0.35s out of Charles during this lap only to lose ~0.3s on the penultimate corner. It's frustrating to have such a good car for 95% of a track and there is just one single corner which takes your whole advantage away.
https://i.imgur.com/72QkjRa.png
It depends which stint you look at, on the hards we lose time at both corners unfortunately, which laps/tyres were you looking at on your analysis?
Going back and looking at the softs and your right, the final corner was OK, not great, not bad and we were being punished universally on the penultimate. Either the tyres or the lighter car allowed us to perform better on the final corner on the softs in the final stint. I would guess that the issue at the front affects the car up to and including mid speed corners, but with the effect greater the slower we are. On the laps below we are .35 to nearly half a second down. The final corner isn't so bad in itself, it is the effect it has up till the start line which is where we start to get parity with the Ferrari.
I didn't post the throttle but it isn't flat out with fuel in the tank, it's about 60% throttle for the bulk of the corner, 80% as the exit starts and then it hits 100% shortly after. 165kph at the apex followed by a lengthy stint of suffering from a slower exit.
I'd love to know how much these cars weigh.
Edit: It is weight. The heavier car suffers in the long mid speed corner as it doesn't have the downforce to drag all the fuel round the corner. This is a snippet from 3 laps of stint 1 where we are 10kph down at the apex and actually slower in the final turn than the penultimate. Looking at the laptimes relative to LEC and SAI, we do indeed improve relative to our competitors as the race progresses. This will be a phenomenon specific to long mid speed corners with a heavier tank.
Final Edit: And now thinking back to Bahrain, the corner that they both hated, was like going round on three wheels and is not dissimilar to the final corner her at Australia, was the final corner at Bahrain.
Give a man a fire, and he will be warm for a night.
Set a man on fire, and he will be warm for the rest of his life.
