Ferrari SF71H
Active: 2018
Team: Mattia Binotto (CTO), Simone Resta (CD), Loic Bigois (HA), David Sanchez (CA), Jock Clear (ED), Corrado Onorato (DCD), Rory Byrne (Tech Advisor), Massimo Rivola (SD), Matteo Togninalli (CRE), Maurizio Arrivabene (TP), Sergio Marchionne (Chairman)
Drivers: Sebastian Vettel (5), Kimi Raikkonen (7), Esteban Gutierrez (reserve)
The SF71H (the code name for the 669 project) is the sixty fourth single-seater car designed and produced by Ferrari to compete in the Formula 1 World Championship. The car was launched online on 22 February, followed by a filming day on 25 February, a single day before testing kicked off at Circuit de Catalunya, Spain.
Rule changes introduced for 2017 led to the introduction of significant aerodynamic modifications and wider tyres, all aimed at increasing performance. Therefore the new 2018 Ferrari F1 car was created to make the most of the experience gained during 2017.
Compared to 2017’s Ferrari SF70H, the wheelbase has increased slightly, with the side dimensions also revised along with the cooling system. The suspension follows the tried and tested practice of using push-rods at the front and pull-rods at the rear, however, their design has been updated based on experience gained during the first season running the wider tyres.
Like on all 2018 cars, the SF71H features the Halo, a titanium bar above the cockpit to protect the driver in case of a crash. The structure weighs approximately 7kg, excluding attachment points while the minimum total car weight has only gone up by 5kg, therefore requiring the team to make weight reductions elsewhere.
Clutch: Carbon fibre plates, by ZF Sachs
Wheels: OZ, magnesium alloy
Weight: 733kg (FIA mininum; incl. driver and lubricants, tank empty)
Designation: Ferrari 062 EVO
Ignition: SKF spark plugs
Total horsepower: More than 900hp
Cooling system: Secan/Marston
Fuel and lubricants: Shell
