Brabham BT33 Cosworth
Active: 1970 - 1972
Team: Brabham Motor Racing Developments
Drive: Rear wheel drive
Steering: Rack and pinion
Brakes: Ventilated disc brakes with 4 piston alloy callipers (disc diameter front: 270mm, rear: 226 mm)
Gearbox: Hewland DG 300 5 Speed Manual
Weight: 550 kg
Wheelbase: 2430 mm
Front track: 1470 mm
Rear track: 1600 mm
Designation: Ford Cosworth DFV 90º V8
Mounting: Mid, longitudinally mounted
Displacement: 2993 cc
Valvetrain: 4 valves/cylinder, DOHC
Fuel feed: Lucas Fuel injection
Power: 430 bhp / 320.8 kW @ 10000 rpm
Bore: 85.7 mm
Stroke: 64.8 mm
Weight: 168 kg
Ignition: Electronic, breaker/coil, Lucas CDI
Injection: Lucas
