Lotus 79 Cosworth
Active: 1978 - 1979
Team: Team Lotus
Team: Peter Wright, Colin Chapman, Tony Rudd, Martin Ogilvie
Drivers: Mario Andretti (5, 1978 / 6, 1979), Ronnie Peterson (6, 1978), Jean Pierre Jarier (55, 1978), Carlos Reutemann (2, 1979), Hector Rebaque (as privateer, 31, 1979)
Team name: John Player Team Lotus (1978), Martini Racing Team Lotus (1979), Team Rebaque (1979)
The Lotus 79 proved to be one of the most succesful Lotus cars ever built. It built upon the ground effect foundations that were laid by the Lotus 78 and added several mechanical features that are still standard in today's F1 cars.
BRM's Tony Rudd first tested the theory in practice, using scale models in the late 60s. However, the idea was not pursued. March was the first to use profiled sidepods on a full-size race car in 1970. The sidepods weren't sealed against the ground and were situated too high to have any effect beside not causing additional drag while making room for extra fuel needed for thirstier races.
Brabham and McLaren experimented with air dams beneath the car but it took some more time until, in 1977, the first proper ground-effect car appeared: the Lotus 78 or, as it was called at the time, John Player Special Mk. III.
Two years before, Peter Wright, Colin Chapman and Tony Rudd conceived of the idea and tested the scale model in a wind tunnel. Initial results were incredible. The Lotus 78 real car did not emulate the model's values entirely, having about 75% of the predicted downforce but what remained was nevertheless impressive.
The ground-effect is based on Bernoulli's equation, known as one of the basics of Fluid Mechanics Theory. It basically states that when a fluid flows through a constriction, its speed will rise and pressure will fall. Since air is also considered a fluid, it could simply be applied to a racing car's aerodynamics as well. If the bottom of the car is shaped correctly, it is possible to create a low-pressure area under the car. Car will literally be sucked to the ground. That phenomenon is known as ground-effect. Since the cornering speed depends on friction between tyres and tarmac, and friction depends on vertical force which is equal to the sum of car's weight and lift force generated by low pressure area beneath the car; the bigger the pressure-fall is, the better the car performs.
To exploit this effect, the car had sidepods shaped as inverted wings thus generating downforce on both sides of the profile. The year before, the edges of the Lotus 78 sidepods were sealed against the ground with brush-like skirts, which is important to prevent outside air from interfering with air passing beneath the car and thus spoiling the effect. These skirts were later replaced by solid rubber skirts. The Type 78 was very successful during 1977. Mario Andretti won 4 times and only missed the title because of poor reliability, Gunnar Nilsson won once.
As the season progressed, Lotus began to work on more radical car, designed to completely harness ground effect as much as possible. By chance or by intention, it turned out to be a beautiful car, maybe the most beautiful open-wheeler ever produced: the Lotus 79 or J.P.S. Mk. IV or Black Beauty.
It had an aluminum monocoque chassis with arc-shaped scuttle. One giant fuel cell, permitted by new regulations, replaced three separate cells featured on the Type 78. The Ford Cosworth DFV engine/gearbox/rear suspension block was bolted onto the chassis' rear end. Radiators were situated into the leading edge of wing shaped sidepods. Front suspension was made up of lower wishbone, top rocker arm and inboard coil spring/damper assemblies. Rear suspension consisted of double wishbones, coil spring/damper assemblies and anti-roll bar. Front disc brakes were mounted outboard, rear inboard, on gearbox's cheek-plates.
Downforce has also risen by approximately 25% over the 78. It proved so good that the design team had to strenghten the car's chassis to whitstand the high cornering forces and the downforce suction. After the modifications, it proved to be even faster than before.
The engine was fully enveloped inside the body panels while the underbody, because of the additional downforce it generated, permitted a smaller drag-inducing rear wing.
Additionally, the Lotus 79 was reputedly also the first F1 car to be designed using wind tunnel and computer design aids. In fact it was the first F1 car to use computers to analyse it in the pits on race weekends.
The Type 79 was not ready for the start of the season but the old Type 78 proved to be man enough for the job, Andretti and Peterson scoring one win each. Andretti debuted the Type 79 in Belgium, the sixth race of 1978 season, qualifying the car on pole, 0.79s ahead of Reutemann's Ferrari and handsomely winning the race. It was the beginning of a remarkable winning streak that saw Andretti winning four more races and Peterson one, plus a total of 9 pole positions and 5 fastest laps. Lotus won the Constructor's title with Andretti and Peterson taking first and second places in the drivers' classification.
The 1978 fairy-tale was sadly destroyed on first lap of Italian Grand Prix. Ronnie Peterson destroyed his Type 79 in testing and, with no spare Type 79 available, had to race a Type 78. A starter's mistake, allowed the race to be started before all of the contenders had completely stopped at their places, provoking a multiple incident in which Ronnie's car hit the guardrail head-on. Both his legs were broken and although his injuries were not thought to be life threatening he died of post-operation complications. What should have been Lotus' and Andretti's celebration, since he clinched his title in Monza, turned out to be a nightmare. There's some amount of irony in it because the only other American World Champion, Phil Hill, clinched his title in Monza as well, and his team-mate, von Trips, died in that race as well.
Peterson was replaced in the team by Frenchman Jean-Pierre Jarier. Carrying unusual start number 55 on his car he proved 79's class by setting the fastest lap in his first race for Lotus. In the next GP he qualified on pole and led convincingly until technical problems slowed him.
While the Lotus 79 was head and shoulders above the opposition in 1978, being the only proper ground-effect car, Lotus was somewhat caught sleeping at the beginning of 1979. The Type 79's successor, the Lotus 80 wasn't ready yet and later would prove to be a flop. The team started the season with 79s painted in Martini – British Racing Green colours, which replaced the famous black-and-gold John Player Special livery. Carlos Reutemann partnered Andretti. The first two races fell into Ligier's lap for they had been by far the best-prepared team running new JS11 cars. However, the Lotuses were still the best of the rest. As the season progressed the Lotus found themselves slipping further down the field. Mexican privateer Hector Rebaque bought one chassis and raced it into 1980 without success.
Incredible developments in the ground-effect area followed, cornering speeds rose sky-high and after several heavy accidents, most notably the death of Gilles Villeneuve, the shaped underbody was banned at the end of 1982. The new era saw flat-bottomed cars with only a rear diffuser shaped for creating downforce.
Designation: Lotus-Ford 79
Constructor: Lotus England
Chassis: Aluminum monocoque
Front suspension: Upper rocker arms, lower wishbone, inboard spring/damper units
Rear suspension: Uupper rocker arms, lower wishbones, inboard coil springs over dampers
Gearbox: Hewland FGA 400 5 speed Manual
Tyres: Goodyear
Fuel tank: Marston, 168l
Fuel system: Lucas
Gearbox: Hewland FG400/5-speed, 55 kg
Instruments: Smiths
Battery: Yuasa
Bearings: Vandervell
Clutch: Borg & Beck
Wheelbase: 2718 mm
Front track: 1730 mm
Rear track: 1630 mm
Formula weight: 575 kg
Wheel diameter (front / rear): 13 in
Rim width (front / rear): 10 in / 18.5 in
Designation: Ford Cosworth DFV 90º V8
Injection: Lucas Fuel injection
Bore X Stroke: 92.5 x 55.5 mm
Capacity: 2997 cc
Power: 475 bhp at 10500 rpm
Torque: 353 Nm at 8500 rpm
Rings: Hepworth & Grandage
Spark plugs: NGK
Weight: 147 kg
