Ferrari 412T1
Active: 1994
Team: John Barnard (TD), Gustav Brunner (CD), Claudio Lombardi (HE), Jean Todt (SD), Luca Di Montezemolo (President)
Drivers: Jean Alesi (27), Nicola Larini (27), Gerhard Berger (28)
The Ferrari 412T1 was used during the first part of the season, until it was replaced by the 412T1B due to the extensive changes that were made during the season. It was driven by Jean Alesi and Gerhard Berger throughout the season, except during the Pacific and San Marino GPs, where Nicola Larini replaced the injured Alesi.
The 412T1 was initially powered by the Type 41 engine, but replaced by the Type 43 engine in qualifying as of the San Marino GP, and in races as of the German GP in Hockenheim, then already in the 412T1B. The Type 43 engine was a complete new design from scratch, done by Claudio Lombardi and Osamu Goto, featuring a wider V-angle between the cylinder banks and a shorter stroke.
Chassis: Composite, honeycomb with carbon-fibre
Front Suspension: Independent torsion arms
Rear Suspension: Independent torsion arms
Brakes: Ventilated carbon-fibre discs
Tyres: Goodyear
Wheels: BBS 13" front and rear
Fuel & Lubricant: Agip Petroli
Length: 4,495.5 mm
Width: 1,995 mm
Height: 995 mm
Front Track: 1,690 mm
Rear Track: 1,605 mm
Weight: 505 kg (with water and oil, without fuel)
Engine (tipo 41)
Engine: Tipo 41 (Ferrari E4A-94)
Designation: Tipo 043
Layout: 65° V12, naturally aspirated
Total Displacement: 3,497.96 cc
Max. Power Output: over 700 bhp
Bore/Stroke: 90/45.8 mm
Timing Gear: 48 valves (DOHC, 4 valves per cylinder)
Fuel Feed: Magneti Marelli digital electronic injection
Ignition: Champion 10 mm spark plugs, Magneti Marelli static
Transmission: Rear-wheel drive, transverse, semi-automatic sequential 6-speed gearbox with electronic control
Differential: Limited-slip
Engine (tipo 43)
Layout: 75° V12, naturally aspirated
Max. Power Output: over 750 bhp
