Ferrari F300
Active: 1998
The Ferrari F300 was launched at Maranello on 7 January, but only after Schumacher ran it at Fiorano a few days before Christmas.
Chassis: Carbon-fibre and composite honeycomb
Front Suspension: Independent, push-rod activated torsion arms
Rear Suspension: Independent, push-rod activated torsion arms
Brakes: Ventilated carbon-fibre discs
Transmission: Rear-wheel drive, longitudinal semi-automatic sequential electronically controlled 7-speed gearbox + reverse, limited-slip differential
Wheels: 13" (front and rear)
Tyres: Goodyear
Length: 4,340 mm Width: 1,795 mm Height: 961 mm Front Track: 1,490 mm Rear Track: 1,405 mm Kerb Weight (with water and oil): 600 kg (including driver)
Designation: Ferrari tipo 047
Configuration: 80° V10
Fuel & Lubricant: Shell
Total Displacement: 2,997 cc
Max. Power Output: over 700 bhp
Timing Gear: 40 valves
Fuel Feed: Magneti Marelli digital electronic injection
Ignition: Magneti Marelli static
