Scuderia Toro Rosso STR5 Ferrari
Active: 01-02-2010 - 2010
Team: Scuderia Toro Rosso
Team: Franz Tost (TP), Giorgio Ascanelli (TD)
Drivers: Sebastian Buemi (16), Jaime Alguersuari (17)
The STR5 is the first car of Toro Rosso that the team is building and designing itself. As the team was using the Red Bull RB5 in 2009 however, there was no need to panic. While still hiring staff in the early months of 2010, the team refrained from making massive changes and limited itself to adapting to the regulation changes.
Surprisingly, the STR5 is looking nearly identical to the RB5, also known as the Scuderia Toro Rosso STR4. It really is a considerable achievement that the outer shape is nearly unchanged after fitting a twice as large fuel tank in the car.
Chassis: Carbon fibre composite monocoque structure
Driver's seat: Carbon-fibre construction, moulded to driver’s shape
Extinguisher system: Scuderia Toro Rosso/FEV
Front Suspension: Upper and lower carbon wishbones, torsion bar springs and anti-roll bars
Rear Suspension: Upper and lower carbon wishbones, torsion bar springs and anti-roll bars
Dampers: Sachs
Wheels: Advanti Racing (front: 12.7in x 13in , rear: 13.4in x 13in)
Brakes: Brembo (calipers, pads and discs)
Overall weight: 620kg (with driver and camera)
Cooling system: Scuderia Toro Rosso
Cockpit instrumentation: Scuderia Toro Rosso
Seat belts: OMP
Steering wheel: Scuderia Toro Rosso
Fuel cell: ATL
Fuel: Shell V-Power
Oil: Shell
Lubricant: Shell Helix Ultra
Gearbox: Seven-speed hydraulic
Clutch: Sachs triple-plate pull-type
Engine: Ferrari V8 Type 056
Total Displacement: 2398cm³
Piston bore: 98mm
Max RPM: 18,000 rpm
Cylinder configuration: 90° V8
Number of Valves: 32
Block Construction: Cast Aluminum
Engine Management: Standard ECU provided by McLaren Electronic Systems (MES)
