Williams FW34 Renault
Active: 2012
Drivers: Pastor Maldonado (18), Bruno Senna (19), Valterri Bottas (Reserve)
Chassis construction: Monocoque construction Laminated from carbon epoxy and honeycomb composite structure, surpassing FIA impact and strength requirements
Front suspension: Carbon fibre double wishbone arrangement, with composite toelink and pushrod activated springs and anti-roll bar
Rear suspension: Double wishbone and pullrod activated springs and anti-roll bar
Transmission: Williams F1 seven speed seamless sequential semi-automatic shift plus reverse gear. Gear selection electro-hydraulically actuated
Clutch: Carbon multi-plate
Dampers: Williams F1
Wheels: RAYS forged magnesium
Tyres: Pirelli, Fronts: 325mm wide, Rears: 375mm wide
Brake system: AP 6 piston callipers all round, carbon discs and pads
Steering: Williams F1 power assisted rack and pinion
Electronic systems: FIA SECU standard electronic control unit
Cooling system: Aluminium Oil, Water, KERS, and gearbox radiators
Cockpit: Driver six point safety harness with 75mm shoulder straps & HANS system, removable anatomically formed carbon fibre seat covered in Alcantara
Weight: FIA Minimum
Wheelbase: FIA Maximum
Overall length: 5000mm
Overall width: 1800mm
Designation: Renault RS27-2012
Configuration: 2.4l V8
No of cylinders: 90° V8
No of valves: 32
Displacement: 2400 cc
Weight: 95kg
Rpm: 18,000
Fuel: TOTAL
Oil: TOTAL
Power output: approx. 750 bhp
Spark plugs: semi surface discharge
Ignition system: high energy inductive
Pistons: aluminium alloy
Engine block: aluminium alloy
Crankshaft: Nitrided alloy steel with tungsten alloy counterweights
Connecting rods: titanium alloy
Throttle system: 8 butterflies
