It's like people think passing the test = complying with the rules.
In other sports that is called "playing to the whistle", and it is the only sensible way to go for a professional competitive player. Sometimes the referees adjust how they whistle, and a few games later, the players adjust to the new limits.
I have a horrible sense of deja-vu. As if flexible front wings coming closer to the ground, and flexible nose cones, and flexible (flattening)
rear wings have been here before. In 2010, and 2012, and 2014...
If I remember correctly, the solution was always the same, FIA fixing the spirit of the rules by adding an extra or harder load test.
IIRC, back then they even went as far as to say in public something along these lines: Yeah... we see it bending, and that would appear to be illegal, but we also have a load test, and it passes it and that would appear to make it legal... we announce now our new load test and until that day we'll see that it is kind of illegal but we'll only actually call it illegal if it fails the new load test and only from that point in time. I cannot find the quote, though (probably from Charlie Withing).
But I might remember wrong, of course.
Edit: Found a few:
CW, 2012:
Q: How and why have the tests for front wing deflection changed?
CW: The rules state the wings (as well as all other parts of the bodywork) must be rigid. We have halved the permitted deflection. Previously the wing was tested with a 1kN load and allowed to deflect 20mm. As a result of this the teams were testing wings until they found a design that deflected 19.9mm under a 1kN load. Our allowances are only a guideline for us and we felt the teams were operating outside the spirit of the rules and clearly designing their wings with flexibility in mind. In our view Article 3.15 takes precedence over Article 3.17 where the deflection limits are quantified. Article 3.17.8 allows us to introduce new tests if we feel our guidelines are not being following in an appropriate manner. The new test therefore moves the pressure point rearwards by 10mm and inboard by 5mm with the permitted deflection reduced to 10mm. We have also told the teams that we may apply the load to just one side of the front wing, an asymmetrical test.
CW, 2011:
scarbs wrote: ↑29 Jun 2011, 17:51
I emailed Charlie Whiting about the
wing movement and what is permitted in this area
"there is no stated permissible deflection of the parts you’re referring to, we do of course have a blanket restriction on any bodywork moving but, in some cases, we define limits given that no bodywork can be designed infinitely rigid.
The slight anomaly you refer to has been investigated and we have told the team improvements need to be made."
CW, 2011:
Thoughts on the legality of current front wings
The flexibility limits are clearly stated. It’s very simple. Under the test load [wings] are allowed to move 20mm.
The only thing we could discuss in the Technical Working Group is whether those limits are too high – but everyone has the same limits, they’re all tested in the same way.
There was often an argument that the cars see more load on the wings, on the track, than they do under our test. But we often double that load to make sure that the deflection remains the same up to the increased load. We test everyone like that. We test with the nose off the car, on the car. We think we have been very thorough. The teams, I think, are satisfied. I haven’t heard any complaints of late. I think the situation is under control.
CW, 2012:
To prevent such flexing from happening, the FIA already toughened their front wing flexi-tests this year. But Red Bull have been able to pass those tests and even then take advantage of aerodynamic benefits by flexing their nose to some extent and hence flexing the front wing in entirety.
What Race Director Charlie Whiting had to say about this saga:-
“I think rigidity, or lack of it, on some front wings has been the subject of a lot of discussion,” he explained. “We’ve attempted to introduce some new tests, which not only tests its vertical deflection but also torsional stiffness of the front wing as well. And we’re going to take a step further next year as well.
“It will be a matter of applying the load. At the moment we apply the load at 790mm forward of the front axle. We are going to move that forward 15cm and back 15cm – so we will do two tests [in those areas].”
Ferrari 2016:
https://imgur.com/r/formula1/k3F89H8
2016, this very site:
atlantis wrote: ↑17 May 2016, 20:27
Formula Wrong wrote:Sorry that this isn't about the testing days, but I've noticed in a recently released on-board video from Vettel's Ferrari on Race-Sunday that the whole
rear wing seems to move a bit down while on the straight and goes up again while breaking:
Source:
Second Video here
I thought all Aero-Parts except for DRS aren't allowed to move like that? I am noticing this for the first time (never noticed it like this on another car before) so it does look kind of weird to me.
Also the engine cover seems to deflate when the car slows down. Or it's just an optical illusion?
plus ça change...
In most cases, the majority is below the average.
