This thread is very strange - many people here seem determined to shoot down
autogyro (and I can understand the frustration).
TBH it is fascinating, but frustrating in equal measure because there is actually very little to talk about.
So, it makes me wonder why is it talked about so much?
Autogyro - I do wish you wouldn't keep hi-jacking other threads to bring your ideas into play. When hoping to learn about current F1 technology it's just a distraction having you talking about something that isn't in use yet and you can't talk about it (but you do).
I genuinely hope you have a great idea tucked away and that it becomes public knowledge soon.
I do have a question - as I understand it, existing gearboxes are actually quite efficient. Perhaps this fundamental efficiency is one reason they haven't changed so much? A case of diminishing returns when more performance is found elsewhere in the vehicle? I know that F1 teams seemingly pursue microscopic gains - and I doubt it's lack of imagination that prevents them looking at alternative transmissions.
So - in terms of real numbers can you share with us your transmission's efficiency compared to a conventional gearbox? I mean literally take a typical F1 engine - how much thrust gets to the road with a conventional 'box and what is the increase with your concept? Tell us in meaningful numbers that even a chump like me can understand
- like convert the extra power available to a theoretical drop in laptime at a particular circuit, or even a simple run through the gears from standstill to top speed.
It must be possible to do - if an existing gearbox has a finite amount of time between each gearchange - then there must be a measuarable amount of time while there is no drive over the five increments between the gears in a 7 speed 'box added to the difference in power available by the improved efficiency.
Also, balancing the gains - how much power would the system need to run itself (assuming it's using electrical energy somewhere).
