Red Bull RB18
BassVirolla
Re: Red Bull RB18
Tim.Wright wrote:
26 Feb 2022, 16:48
AeroDynamic wrote:
25 Feb 2022, 19:22
He's claiming it's a pro-dive but I'm pretty sure that's not the case. My estimations put it at around 30% anti-dive.
I'm not expert in kinematics nor suspension, but I also see it rather pro-dive...
Possibly to increase front downforce under braking and circumvent the minimum height rule.
Edit:
To me, it looks like point C is going to be over point A, not under A.
lio007
316
Re: Red Bull RB18
All teams bar one have problems with the minimum weight. Rumour has it the RB18 is the most affected.
Marko told that yesterday has been a meeting to discuss another increase of minimum weight, although he doesn't expect a consensus to be found. He also said that Red Bull is going to bring a weight-upgrade (i.e. downgrade :) ) in Bahrain.
https://www.motorsport-magazin.com/form ... -anhebung/
Re: Red Bull RB18
Matt explains it well.
Tim.Wright
330
Re: Red Bull RB18
BassVirolla wrote:
26 Feb 2022, 18:04
Tim.Wright wrote:
26 Feb 2022, 16:48
AeroDynamic wrote:
25 Feb 2022, 19:22
Edit:
http://performancetrends.com/Definition ... i-Dive.gif
If it was pro-dive, point Ain your diagram would be under the ground.
This is my estimation - looks close to but above the ground.
Chuckjr
38
Re: Red Bull RB18
Tim.Wright wrote:
26 Feb 2022, 18:30
BassVirolla wrote:
26 Feb 2022, 18:04
Tim.Wright wrote:
26 Feb 2022, 16:48
Edit:
https://dm2306files.storage.live.com/y4 ... pmode=none
Tim, do you think Newey did this radical geometry more for aero purposes or mechanical purposes?
Watching F1 since 1986.
humble sabot
27
Re: Red Bull RB18
Are you sure that it's at all feasible that the CG of the entire vehicle is only 250mm off the ground? That's not much above the crankshaft.
With a driver on board? I can only think of two things on the entire car with their mass centroids that low, the battery and the gearbox, and I'm not that sure about the latter. The driver's, and the engine(taken as a package) will both be a touch above that, especially taking into account regulation ground clearance. The tub's extra mass for safety is from chest to head height.
the four immutable forces:
static balance
dynamic balance
static imbalance
dynamic imbalance
jjn9128
778
Re: Red Bull RB18
humble sabot wrote:
26 Feb 2022, 21:23
250mm would have been quite conservative 15-20 years ago. Sounds about right for these cars.
#aerogandalf
Lefty8
Lefty8
Re: Red Bull RB18
If I recall from previous rules cycles the minimum CoG of the car was a rule specified height. Was that scrapped or is it still enforced? I don't recall it being dropped from the regs
humble sabot
27
Re: Red Bull RB18
jjn9128 wrote:
26 Feb 2022, 22:30
20 yrs ago the engines were naturally aspirated, there was no halo, and they were using exotic materials in the upper portions of the engines, and there was no centreline cooling. Also, everybody was running significant ballast. Since the v6 most teams have struggled to hit minimum weight.
static balance
dynamic balance
static imbalance
dynamic imbalance
Re: Red Bull RB18
Lefty8 wrote:
26 Feb 2022, 23:50
The engine is the heaviest thing in the car so the CG of the engine is a good starting point. Fuel gearbox and and wheels bring that up higher. 250mm sounds like a good estimate IMO.
DiogoBrand
73
Re: Red Bull RB18
lio007 wrote:
26 Feb 2022, 18:22
Could they not just increase the height of the step where the wooden plank and the skid blocks sit?
I know changing the step would possibly not be viable without making a new car, but maybe just increase the thickness of the plank and the blocks for the time being.
Their purpose is to avoid the floor bottoming out and stalling in the first place, so use them for that.
Edit: I meant change the rules to enforce that, not that a team would willingly do that.
jjn9128
778
Re: Red Bull RB18
DiogoBrand wrote:
27 Feb 2022, 03:33
lio007 wrote:
26 Feb 2022, 18:22
If the FIA felt strongly enough that the porpoising was a safety issue thickening the plank would probably be their only recourse
#aerogandalf
Tim.Wright
330
Re: Red Bull RB18
Chuckjr wrote:
26 Feb 2022, 20:12
I have no idea, without looking at what other cars are doing it's pretty hard to draw any decent conclusions.
Tim.Wright
330
Re: Red Bull RB18
humble sabot wrote:
26 Feb 2022, 21:23
Not really. If it's higher, then the calculated anti-dive will be lower than what I stated.
Lefty8 wrote:
26 Feb 2022, 23:50
The engine CG height was(amd maybe still is) regulated. Full vehicle CG height is free.
henry
324
Re: Red Bull RB18
Tim.Wright wrote:
27 Feb 2022, 14:19
humble sabot wrote:
26 Feb 2022, 21:23
Lefty8 wrote:
26 Feb 2022, 23:50
PU CG minimum 200mm above the Z plane. I’ve always assumed 300mm for load transfer calcs particularly for the high rake cars. Perhaps it needs to be a bit less now.
