2023 - McLaren Formula 1 Team
Macklaren
Macklaren
Do we know if this is Part 3 of the B-spec package or if this is just a small incremental step (there is some talk from Andrea about bringing the Part 3 "soon after" the break rather than in Zandvoort and Zak said "slight upgrade" in the video though unclear if that was part of his Tyrell joke)
mwillems
44
IIRC Stella had previously mentioned about a small upgrade coming to Zandvoorte, this upgrade come from another parallel piece of work being developed and that the upgrade was a relatively simple piece of work and considered a low hanging fruit. i.e. a relatively decent gain for the small change identified, I may be mis-remembering though and perhaps it really is the final piece of the upgrade package.
-Bandit
f1rules
f1rules
594
Its being speculated on twitter,(and i agree) that maybe tweaks to the fw will be tested, due this rig being fitted on landos car, its normally used to meassure changes at the front
Tomsky wrote:
24 Aug 2023, 16:29
CjC
CjC
f1rules wrote:
24 Aug 2023, 19:34
Tomsky wrote:
24 Aug 2023, 16:29
They brought a new front wing to Silverstone though?
Just a fan's point of view
Emag
Emag
84
Some other sources are reporting changes to rear wing + beam wing and underbody stuff.
Rakes mounted there would be more inline with tests to the underbody since its before the tunnel entrance, but I am not sure.
f1rules
f1rules
594
Well, you always meassure behind the change, for to see the result in flow, can be they want to test different front rideheights and its influence also, but im thinking something new at the front
FittingMechanics
FittingMechanics
16
Good to see the team bringing more updates. When listening to them talk before the race, they seem confident (Zak). I would expect the team to do well here.
mwillems
44
Emag wrote:
24 Aug 2023, 20:45
They have brought minor efficiency changes to the rear.
Not aware of front changes but they may be testing setup at the front to understand how it is affecting airflow behind the wing to support some current dev work, which I think is the more likely explanation.
They did aero testing before with this wing, so you'd assume there's some configuration they want to analyse. Perhaps a setup that didn't extract the results they expect or a configuration they may want to run after future upgrades.
-Bandit
Ben1980
Ben1980
Haven't they sort of said, they are re-evaluating the upgrades? Following the success of the initial ones? Without saying they aren't using them. More checking it against than a big load.
Or maybe I misinterpreted.
Ground Effect
Ground Effect
Does McLaren still have obligations on the young driver FP sessions, or did Oscar’s early season’s FP outings take care of that?
MCLvamos
MCLvamos
Hope this is just a higher fuel load or something. If this is representative in any way we are a bit behind. Lots of bouncing on Norris' onboard too.
CjC
CjC
MCLvamos wrote:
25 Aug 2023, 13:27
Didn’t look too bad in the end?
MCLvamos
MCLvamos
CjC wrote:
25 Aug 2023, 13:39
MCLvamos wrote:
25 Aug 2023, 13:27
still quite a way off Alonso and Hamilton. Then again McLaren often don't show too much of their hand on a Friday: I recall it was similar in Silverstone. Hopefully that's the case and maybe they show a little more in FP2 or tomorrow.
BMMR61
Lots of data collecting, not too worried about lap times at this stage. New floor on Aston looks like it’s delivered a good step.
Darth-Piekus
-1
Considering Mclaren tends to have their engine way down during practise I would say it was a good result
