djos wrote: ↑06 Mar 2024, 00:32
CHT wrote: ↑06 Mar 2024, 00:01
Looking at the speed trap in Bahrain, I don't think Ric will have it easy to pass Kevin with DRS. So its just a assumption that if
Yuki move aside Ric will over take Kevin and score points.
The gap to P10 are just too big
It's not just top speed, soft tires give you better traction out of the corners which combined with DRS will let you get alongside the other car and then out brake them. The problem was
Yuki delaying letting him by
I went back and rewatched it - here's what happened:
Lap 47 -
Yuki catches KMag and gets in DRS range part way through the lap
Lap 48 -
Lap 49 - Dan catches
Yuki at the start of the lap (within 1.5s)
Lap 50 - Dan gets gap to under 1s and gets DRS
Lap 51 - Driver Swap ordered (TV replay's it just as Lap 52 ticks over, but it was a replay)
Lap 52 - End of the straight,
Yuki chops Daniel and doesnt let him pass
- halfway through the lap,
Yuki again ordered to swap,
Yuki says "you are kidding me"
Lap 53 - 1/4 of the way through, Daniel say "I dont need to say anything"
- 1/2 way through
Yuki finally swaps places
- then Max catches and passes
Yuki
- a few corners later, Max catches Daniel forcing him to drop his battle with KMag
Yuki had 3 laps to overtake KMag before Daniel got into DRS range, and 4 laps before the Team order him to let Daniel past.
Daniel got stuck behind
Yuki for 4 Laps, almost 3 laps more than he should have been, which compromised his soft tires. Daniel also got chopped by
Yuki at the end of the straight - looking at the onboard, it's clear Daniel thought
Yuki was taking a wide line to let him through.
This was all compounded when Max caught and lapped them both - it's little wonder that Dan was then unable to get by KMag, his tires were mostly used up thanks to
Yuki disobeying team orders.
