@Ogami
Yeah, the 1200kg overall figure was the second thing that got me thinking. I also considered it to be around 2,5t by last year. BTW I took a look at my Georigio Piola Book from 2000 where he stated, that the cars of that year had a total downforce of around 1600kg on average.
So if you say that 15% was the target, what was the ratio in 2008? 50%? 40%?
Much to one of my mistresses' disappointment, I amused myself last night with taking Om's figures for a spin and found something rather interesting.
If we begin with a 24000 N (2400 kg) total downforce at top-speed, 305 km/h (85 m/s). With a squared relation between speed and force, this results in half of that downforce, 12000 N, at 215 km/h (60m/s).
And for the sake of argument, with a contribution from diffuser and floor of 20% it means 2400 N at the same speed, 60 m/s, which with an estimated area of 2 sq. meters in turn would suggest an air-speed under the car of 75 m/s.
Now, imagine that Brawn with their "innovative" diffuser, manages to increase air-speed with 4%, from 75 to 78 m/s, downforce from diffuser and floor would jump from 2400 to 3000 N or 25%.
Overall downforce at 215 km/h, would as a consequence increase from 12000 to 12600 N or 5%.
On a curved section, everything else equal, a 5% increase in grip should in theory result in a 2.5% higher speed, when lateral force is m*v^2/R. With 40 seconds, or half the lap, spent in curves, it gives a 1.0 sec advantage over the whole lap.
Try that one for size, Ciro?
As a sidenote:
I always believed, that when anyone stated that those diffusers would be xx% better, he meant the increase in downforce for a given drag, not the air speed. Would you agree on that?
BorisTheBlade wrote:As a sidenote:
For a diffuser, the drag is relatively independant of downforce created.
Therefore the car drag levels will be more dependant on car speed.
Hm,
I know that it's only a small portion compared to overall drag. But in terms of efficiency there's always a denominator.
My whole point is:
If they talk about havin improved the diffusor by like 20%, do the talk about 20% more [downforce]/[drag] or do they talk about 20% more [air speed under the car]/[over the car]? Cause seeing these calculations it'd make a huge difference.
When knowing a few journaists Boris, it is sometimes difficult to know precisely what they mean, or even if they have a technical clue what they are talking about.
With the shining exception of scarbs of course.
My guess is that if anyone talks about "improving the diffuser with 20%", what they really mean is that the downforce generated by the entire floor has increased by 20%. kilcoo?
Callum wrote:ah right, the ram effect is what i was getting at.
Oh, another thing, which may be a reallly simple/stupid question..
How is the car travelling through static air the same as moving air through a static car...?
Thanks Conceptual.
Confused?
Quick question after reading Simons book as well...
Why would vortex sealing of the skirt area be better than a saw-tooth edge that would generate vorticies as air was sucked under?
There is a picture in his book that shows a single vortex on either side being sucked under the car, and leading to some VERY low pressure areas, and an increase of mass flow.
THAT is what doesn't make a lot of sense to me, so if anyone can explain, I would be greatly appreciative!
Not only a downforce increase but remember a well-designed diffuser will reduce pressure-drag (or form-drag, whatever you want to call it)...
Conceptual: I have a sneaking suspicion that your concept wouldn't improve mass-flow under the floor because you are creating vortices all along the length (each 1/n in size) instead of a single, full-length vortex of n length. Remember vortices propagate along a length so trying to stimulate them by using a serrated edge may result in dissipating of the vortex reducing it's effect. However, this is all just my sneaking suspicion - you'd need to test it really.
Conceptual wrote:There is a picture in his book that shows a single vortex on either side being sucked under the car, and leading to some VERY low pressure areas, and an increase of mass flow.
That is trying to get the same effects as a LERX.
I would have thought the restricted area between the ground plane and car floor (and associated friction) would limit the application of this. But I cannot be 100% on that.
xpensive wrote:My guess is that if anyone talks about "improving the diffuser with 20%", what they really mean is that the downforce generated by the entire floor has increased by 20%. kilcoo?
My take on it too - effectively an improvement of 20% on -CL.
Any body remember how the diffuser works.. I would like to see some on that. The whole transitioning effects and all. I want somebody to remember it for me hehehe.
Last thing i remember from school was some length vs pressure thing.
kilcoo; If my sketchy calculations from Wed Apr 01, 2009 6:33 am is anything to go by, my reflection is that this is an extremely sensitive component, why either a standard-floor or a flat-bottom rule all the way might be the way to go for the FIA, if they are serious abut draconian cost-cuttings?
xpensive wrote:kilcoo; If my sketchy calculations from Wed Apr 01, 2009 6:33 am is anything to go by, my reflection is that this is an extremely sensitive component, why either a standard-floor or a flat-bottom rule all the way might be the way to go for the FIA, if they are serious abut draconian cost-cuttings?
Well... getting that past the teams would be an ordeal.
In principle, I agree with standardising it - it is an unseen element. But in getting rid of it, would that remove F1 from being the quickest cars around a race circuit in the world?
Perhaps a standard floor from a certain distance behind the cockpit is the best solution... and use the current OWG envisaged diffuser.
