Mercedes W12
Bandit1216
21
Re: Mercedes W12
Using the steering for squatting would be brilliant. But I think it's a a little bit far fetched. To me it's looks like Mercedes copied some things of RB and just did it better. A lot better even.
Or is that a too objective opinion, me being Dutch?
But just suppose it weren't hypothetical.
El Scorchio
Re: Mercedes W12
Bandit1216 wrote:
19 Nov 2021, 12:31
Not really- all the teams do copy and evolve aspects of each other's design which they see as effective, after all.
For example:
Ferrari's high sidepods
Mercedes' narrow nose and cape
adrianjordan
Re: Mercedes W12
Sorry if I've missed them, do we have any photos of these "scorings" on the rear wing that Horner et al are referring to?
Favourite team: McLaren
Re: Mercedes W12
Formula 1 – Analysis of the Max/Ham duel in the Brazilian GP and Mercedes speed
Full Article
https://www.newsf1.it/formula-1-analysi ... des-speed/
Owen.C93
Owen.C93
177
Re: Mercedes W12
That data looks completely wrong, I think the X axis is time instead of distance.
Anyway here's the rear wing area in question from Austria. Haven't found any similar from Brazil.
El Scorchio
Re: Mercedes W12
adrianjordan wrote:
19 Nov 2021, 14:45
Shovlin was asked about the scorings after FP2 and he said (I'm paraphrasing, but this was the gist) that he didn't get what they (RBR) were talking about and as far as he was concerned there aren't any.
Owen.C93
Owen.C93
177
Re: Mercedes W12
Here's an overlay gif comparing the W12 in USA when it's stopped and at speed. You can definitely see the slot gap open up.
Raw images:
And preempting the arguments about angles. That static shot should be a less favorable angle because it's from a higher position which should show the slot gap slightly more.
the EDGE
the EDGE
67
Re: Mercedes W12
To me it looks like the the angles are the opposite to what you claim, the static shot is a lower angle and the moving image taken from higher-up
You can clearly see more of the back of the air-box in the second
El Scorchio
Re: Mercedes W12
Owen.C93 wrote:
19 Nov 2021, 18:22
https://i.imgur.com/seOnrMS.gif
Raw images:
https://i.imgur.com/eI6ZbDx.png
https://i.imgur.com/yViJF3P.png
The T wing is different in each photo, is it not? Surely it's not the same car- or at least the same car with the same setup - in each?
dans79
267
Re: Mercedes W12
Lets not forget about how the rear squatting at speed would also change the angle, and how the gap is perceived!
201 105 104 9 9 7
Owen.C93
Owen.C93
177
Re: Mercedes W12
OK here's an image from Brazil from a lower angle and you can see daylight in the slot gap.
dans79
267
Re: Mercedes W12
Owen.C93 wrote:
19 Nov 2021, 19:34
https://i.imgur.com/cBNxw4h.png
You realize that's allowed right? the only thing that's regulated is the maximum and minimum spacing between them.
for example, you can see right through the gap.
https://maxf1.net/en/2018-italian-gp-re ... rear-wing/
and
https://www.formula1.com/en/latest/arti ... ve7j3.html
and
https://f1i.com/news/406057-ferrari-for ... hange.html
201 105 104 9 9 7
Owen.C93
Owen.C93
177
Re: Mercedes W12
I didn't say it wasn't allowed. I'm just showing the gap when stood still and when at speed to try and figure out what RBR are referring to.
Here's 2 decently similar angles from high speed and stood still. Need to find something a bit sharper and a higher speed though.
jumpingfish
53
Re: Mercedes W12
Owen.C93 wrote:
19 Nov 2021, 19:49
https://i.imgur.com/xMV2mvR.png
https://www.racefans.net/2021/11/19/no- ... _Promotion
pursue_one's
97
Re: Mercedes W12
Red Bull team principal Christian Horner claimed earlier today the W12’s rear wing features “score marks” which they suspect is linked to Mercedes’ strong straight-line speed in recent races.
“Make no bones about it, if we see it on the car here it will be protested,” Horner said.
Red Bull’s suspicions are believed to concern a discolouration seen on the inside of the rear wing endplate of the W12 next to its lower flap, beneath the DRS-adjustable upper flap (pictured).
